Question about Honda Garden
Husky 2400 psi honda engine ran fine all day
Husky 2400 psi honda engine ran fine all day stopped to put gas ,starts up,but now minimal pressure coming out ,what could be the reasons for the lack of pressure
  • Anonymous Mar 18, 2014
    engine light turned on after about 2 days after I put gas in my honda crv 2008.
  • 174 Answers
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Posted on Jun 27, 2009
SOURCE:
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Sears pressure washer
sounds like the engine is over heating have you checked the oil?remove the top cover from the engine and look for a mouse nest
Jul 27, 2012 | Craftsman 3000 PSI 28 GPM Honda Powered...
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
I have a Husky 3000 PSI - Was working fine (I think ( for about hours. All of a sudden it seemed to get a burst of energy and worked faster. Shut it off to add gas. When I started it up again, there...
Pressure washer are pretty simple, a few pistons and a spring device to control the pressure. The problem could be a broken part inside the pump itself. With any luck it could be the linkage between the pump and the motor. If there is a oil window in the pump or a pump oil fill plug open this and with the engine switched off slowly pull the starter cord and see if the pump works are moving. (don't do it fast or let the engine start or there will be oil everywhere.) this will tell you if the pump is working. It could also be the diverter this wold be harder to diagnose you could go and replace the whole pump also.
Aug 09, 2011 | Honda Pressure Washer PSI 3000
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Husky ran great for couple of hours. Now no pressure at all. Water comes thru for suds, but no near enough. Engine runs fine but will not build pressure. Checked for trash blockage-all clear. Thanks,...
Same old problem... water admitance valve sticking.
Remove the valve spool and clean the bore with crocus cloth on a dowel rod.
Replace O rings and lube lightly with plumber's grease. Reassemble... good as new!
The valve senses pressure and blocks further input water. It sticks in the high pressure position blocking water flow.
Aug 05, 2010 | Honda Pressure Washer PSI 3000
Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
Jun 29, 2010 | Honda 2500 PSI Gas Pressure Washer
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
658 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
