Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Very same issue...
Has been a problem since day 1 , repair tech says " cant fix it if I cant see it doing it- it only happens after about 45 min of operation - if its hotter out I KNOW it will do it....
  • phil643 Jun 27, 2009
    oh...sorry, I thought I was adding to an existing thread.....
    My auto transmission will start to whine and the tractor slows down & then stops. I cant go forward or reverse ...I can count on it happening on a warm day after about 45 min of continuos use. I have almost 2 acres to mow & have to hit it in 2 stages- the tractor will be fine after a hour or two time out... So Im guessing its a heat or pressure thing w/ the tranny . OH and I would have to say, it has never been a very fast mover , considering the 20 hp Kohler engine it has....
    -phillip
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello p, what is the mower doing?
UL code keeps coming up at last 9-10 min of spin cycle will not finish load What could be causing this? Is it bent suspension rods?
I replaced the suspension rods but it not resolve the UL issue - still gave UL code even when run with no clothes in load -so I called Maytag for service.(Purchased REPAIR PLUS 1 which covers this repair and one year maintainence contract). Tech from local subcontractor service came out and said it was the bearing. I am still waiting for repair 10 days later because service contract required "approval" before he could order parts (7) including rotor and sensor although to fix bearing tech should only need bearing kit & tool to pull old bearing.
May 20, 2016 | Washing Machines
What it the next step in find a solution for my tv. replaced the power board, but same issue still happens. TV will cycle on & off for 45 min. with a screeching nose then go to no picture but audio
Sounds like backlight inverter board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screetchng sound are the common fault with this board.
Oct 12, 2015 | Samsung LN46A500 46 in. TV
I have a 1995 buick century special that I drove for a while with a leaking transmission seal because it was my only way to work. It had other issues while this was going on I couldn't afford to address. I...
Have your fuel pressure checked at the fuel rail. It should be just over 40lbs of pressure. If it is lower than 40 I would have your pump changed. From your description it sounds as if your pump is getting weak. And if you have plenty of pressure I would look towards the DIS module or the crank sensor, but the crank sensor should set and engine light.
Sep 26, 2014 | Cars & Trucks
04 Gsxr600 jerking and engine dies after riding for awhile.
I have an 05 with the same problem. Sounds like your STVA went out. Do you still have your butterflies wired open? I know how to repair the stva fixed mine, and saved hundreds....if your still on this post email me so we can get our bikes fixed. also check your kick stand sensor! This can malfunction and cause same stalling problems.
Apr 22, 2012 | 2004 Suzuki GSX-R 600
2007 C90 after rideing it for about 45 miutes the Battery goes de
Have your Regulator/rectifier checked , and have your ststor checked also . Both are not hard to fix , regulator about 15 mins and ststor about 45 mins .
Mar 22, 2010 | 2005 Suzuki Boulevard C90
Abs and brake light is flashing on my 99 audi a6 quattro i cant comunicate with the abs module
If you need to repair the brake module, there is a fantastic article, complete with photos, at http://www.audiworld.com/tech/elec116.shtml
I followed this example for my '98 and now it works perfectly. I found a shop on eBay to rebuild my module (lifetime warranty) for under $200. It took me about 1 hour to pull it off and about 45 min to put it back on with minimum shop tools
Jun 18, 2009 | 1999 Audi A6
2004 VW Touareg won't start
I had/have the exact same problem with my 2004 Treg. I took it to the dealer in April and they told me it was the fuel pump and replace them. Everything was fine until the other day when it happened again. I took it to a local mechanic who told me it was the crankshaft sensor. If it happens again I'm selling the car for scrap!
Jun 02, 2009 | 2004 Volkswagen Touareg
No power
I meant to add to my posted reply to this problem in that we're having the same problem with this TV:
This is a possible solution to the problem that unfortunately did not work for us. When we called the 1-800 support number for Funai, the tech on the line had only one suggestion other than it needing a repair shop fix. He suggested that we unplug its power cord for 45 minutes. This, he said,"would let all the power drain out of a big chip inside on its switchboard and let it reset itself upon being plugged back in". Sounded silly to me but in regards to being reset it does sound possible as most electronics these days do need to be reset time to time to fix troubles. I must add in regards to Funai that the tech was very kind, compassionate, empathetic and helpful regarding our trouble with the TV. I say that because I ranted against Funai in my eariler posting. I still stand behind my thoughts on that rant though because deceptive trade practices are basically a form of stealing hard earned money from a person for a product that is sold to them under deceptive practices. Buyer beware.
Nov 09, 2008 | Sylvania 6424TF 24" TV
Do i need a new circut board???
Good Day;
I don't think so. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
I have repaired 50 or 60 of these.
Good Luck, big IRISH.
Aug 16, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
163 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
