Question about Lexmark JetPrinter X1185 All-In-One InkJet
I need user guide link for Lexmark Printer model 4437-001
SOURCE:
Printerguy
  • 31 Answers
SOURCE: error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Posted on Aug 21, 2007
Ajkill
  • 2035 Answers
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Posted on Mar 15, 2008
  • 28 Answers
SOURCE: Error :1203. Consult user guide
1: Make surethe All-In-One is powered on.
2: Pull thecontrol panel towards you, and then open the cartridge access door.The print cartridge carrier moves and stops at the loadingposition.
3: Pull the old cartridges towards you,and then lift them out.
With the cartridges outof the printer, shut the access door and the control panel.
Power the printer OFFand then back ON.
Check the operator panelto see if the same error has returned or if a new message hasappeared.
If the message displayed is 1203,there is something wrong with the printer hardware.
If themessage now displaying is Cartridge Missing, do thefollowing:
4: Reinstall the cartridges into the printer.
Insert the color cartridge in the left carrier.Insert the black cartridge in the right carrier.
5: Push back firmly on the cartridges until they snapsecurely into place.
Close the cartridgeaccess door, and then close the control panel.
If the 1203message is still present on the operator panel, you need toinsert one cartridge at a time to determine which cartridge isproducing the failure.
With one cartridge in thecarrier, close the access door and control panel.
Check the operator panel.If the 1203 error is displayed, this cartridge isthe defective item.
If the Cartridge Missing messageis displayed, the second cartridge is producing the failure.
Posted on Nov 12, 2008
  • 13434 Answers
SOURCE: need users guide for lexmark 5400 series
Hey,
user manuals and other documents are available for your printer at http://www.lexmark.com/publications/pdfs/2007/5400-plus/en.html
Let me know if you need anything else. Thanks,  Ekse
Posted on Mar 04, 2009
pineworks
  • 4345 Answers
SOURCE: I have a major paper jam on my Lexmark printer,
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
How can I obtain a User's Guide for a Lexmark X6650 all in one printer?
You can download the Lexmark user manual and printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Mar 28, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
I need to know hook up to sen faxes
You can refer to the Lexmark X7170 User's Guide for the instructions on how to setup the printer for faxing. If you have already installed the printer software on your computer, you can access the user's guide by going to the Start menu -> All Programs/Programs -> Lexmark X7100 Series -> User's Guide. Go to Setting up the All-In-One with equipment for the setup instructions. If not, you can visit the Lexmark website using this link Lexmark X7170 User's Guide.
I hope this information has been helpful. Thanks.
Dec 27, 2010 | Lexmark X7170 All-In-One InkJet Printer
What do the Picture symbols mean on the side of the printer?
You may check the Lexmark X2500 User's Guide for reference. If you have the printer software installed on Windows operating system, you can view the user guide by going to the Start menu -> All Programs/Programs -> Lexmark X2500 Series -> User's Guide.
You can also download it for free from the Lexmark website using this link Lexmark X2500 User's Guide. Scroll to page 14 for description of the control panel buttons for the printer.
Dec 15, 2010 | Lexmark X2500 All-In-One Printer
I need instructions on how to use my Lexmark X5650 scanner
Please refer to the Lexmark X5650 User's Guide. If the printer's software is already installed on your computer and you're using Windows, you can view the user's guide by going to the Start menu -> Programs -> Lexmark X5600 Series -> User's Guide. If not, you can download it for free using this link Lexmark X5650 User's Guide.
Thanks
Dec 12, 2010 | Lexmark X5650 All-in-One InkJet Printer
I need a free users manual for lexmark x4270 all-in-one inkjet printer
Download the Lexmark 4200 series user's guide from the Lexmark website for free.Click on this link Lexmark 4200 User's Guide. Thanks.
Nov 11, 2010 | Lexmark X4270 All-In-One InkJet Printer
I need to connect my phone line to my printer to enable me to send faxes, how do I do this.
Refer to the printer's User's Guide on how to connect your Lexmark X5470 to your telephone line for faxing. If the printer software is already installed on your computer, you can access the printer's User's Guide by going to the Start menu -> Programs -> Lexmark 5400 Series -> User's Guide (applicable to Windows OS). If not, you can download it from the Lexmark website for free using this link: Lexmark 5400 Series All-In-One User's Guide. Scroll to page 12 for the fax setup instructions. Also, check page 71for faxing instructions (sending, receiving, etc.). Hope this helps.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Nov 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
I need an owners manuel for my lexmark 2500 series printer,scanner, and copier model # 4428-001
Hello. Here's a link to the Lexmark website where you can download the User's Guide for you Lexmark 2500 Series printer,scanner, and copier model # 4428-001. Hope this helps.
Mar 25, 2010 | Lexmark C533DN InkJet Printer
Install printer
Not sure what you mean about being "compatable with".
If you need the setup guide, here is a link:
Lexmark 4200 Series Setup
There is also an online user guide available at:
Lexmark 4200 Series User Guide
The setup guide is a PDF file, but the User Guide is an HTML (web) link.
Hope this helps. If you need more advice, just comment back.
Thanks for using Fixya.
Mar 09, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer installation
Hi Roger22
you can find a complete .pdf guide thats easy to understand by clicking the link below !
Lexmark X1100 series User Guide.pdf
Worry not , the X1100 series should match your x1150 model installation procedure!
Whatever O/S you use , you can get the Lexmark drivers to match from the Lexmark downloads section for X1100 series below ( also links to other models as well !)
Lexmark X1150 drivers & downloads / Choose your O/S
May 22, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
191 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
