Question about Dometic RM2852 Refrigerator
Dometic RM2862 will not come on at all, no blown fuses or tripped breaker. no lights come on either. Any thoughts?
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    Plug a lamp or radio into the outlet, does it work? Tracy
I have the same problem Have replaced the power Modular still Refrig light or anything styill doesn't work. Anyone have any suggestions?
Posted on May 21, 2010
    New Friend:
My light operates once I reset the thermal switch, but after 10-15 minutes it trips again, anyone know the cause of this. I have replaced this switch 2 weeks ago, I feel the pipes get hot, but again it trips after 10-15 minutes. Any suggestions????
Posted on Aug 02, 2016
    New Friend:
  • 4 Answers
There should be a shield on the right side of the access compartment. behind the shield will be 2 red wires leading up to a small round disk about 10in up from the bottom of the unit on the side of the heat exchanger. Between the 2 connectors on the disk there will be a small black button. Press the button firmly so it clicks (This is a SAFETY DEVICE, DO NOT BYPASS) and then check to see if the lights come on and the unit operates.
Posted on May 24, 2013
  • Cory Beebe Jun 30, 2013
    I do not see any other access compartment coming from the outisde access panel. I have absolutely no power to my RM2862.
Why do the chck light come on the dometic refrigerator when i turn it on
turn off and on then if same check fuse in back on board
Sep 14, 2016 | Dometic Refrigerators
Answer not provided. Please read my question.
is it 110 or 220? if it is a 110 first check your breaker/ fuse panel for tripped breaker or blown fuse if 220 it would be a double breaker. if you find tripped breaker remember some panels require you to turn the breaker fully off then back on to reset. if 110 and no blown breakers, check your laundry room for a GFI (ground fault interrupt) outlet. make sure that it is not tripped either. to reset that just push the reset button on the outlet. best of luck to you
Nov 19, 2015 | Dryers
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
Replace fuses in dometic rm2862
check back board for fuse or loose connections
Jan 02, 2013 | Dometic RM2852 Refrigerator
Air conditioner not working plugged in or on generator, heat not working either--nothing 2000 jayco designer
If you have AC hydro for sure to unit, perhaps a fuse in the 12 volt DC panel has blown, or in thermostat itself. Hear any clicking at AC unit when turned on? If not, check all your fuses in 12 volt DC panel. Check breaker didn't trip also on 120 VAC.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Dometic RM2862 Can you reset the thermo fuse? Current going to it but nothing going out and wouldn't this cause the unit not to work at all?
It probablby has a timer in it. You can reset the timer by turning it clockwise, and the compressor would come on again. It is usualy located under the concoles where the setting button is located. Look for a small hole under that console. If a thermal breaker is making the compressor cut off, it is usually located on the compressor where all the wiring are going in, along with the starting capacitor. Usually if the compressor is overheating and making the thermal breaker go off, there is a problem with the compressor, or it is low on refrigerant. A low refrigerant will make a compressor overheat. Furthermore if the compressor has been being overload by low refrigerant, it will be damaged sooner or later, by overheating the elecmotor inside and causing a short. If resetting the timer don't work and it is indeed the thermal breaker, unplug the machine and get it service, which I hope the compressor is still okay.
Jun 27, 2009 | Dometic RM2852 Refrigerator
Throwing breaker when plugged up to AC
The heating element most likely has a short in it. Pull the to leads leading to it test the ohms to see if you have a short
Aug 09, 2008 | Dometic RM2652 Refrigerator
Neither fan or compressor will com on
You have a short circuit in the system at some point. A blown fuse on the circuit board indicates a short in the control circuit. Tripping of the breaker indicated a high voltage draw from the compressor. Check the compressor motor terminals with the wires removed and the power off. Use an Ohm meter from a terminal to ground. You should have no reading. If you have any reading the compressor motor is shorted out and the compressor is done.
Jun 17, 2008 | Dometic Rooftop RV Air Conditioner
Dryer runs but won't heat up
Is the fuse bown.or is the circuit breaker tripped?
if the fuse is blown or the circuit breaker tripped .the dryer might tumble but not heat.
Dec 28, 2007 | Kenmore 60172 Electric Commercial Dryer
Dometic RM2852 Refrigerator Logo
1,079 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
