The washer will not spin and open door clothes are locked in it with water standing
  • Washing Mach... Master
  • 8,220 Answers
Access the trap door below and clean the pump filter. get any water off the bottom of the unit. reset it unplug it and retry it. It is impossible to tell you a good answer based on your vauge question, why don't you t your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
Posted on Jun 27, 2009
My washer stopped during the spin because it got out of balance. Now I am unable to open the door and my clothes are stuck in the machine.
Non of the answers are helpfull. Unplug power.Remove bottom panel and there you find a door lock release. Pull n the door will unlock. Drain water from from pum(it has drain tube). Remove clothes. Move n push the tub a little on each side. Now plug drain pipe. Close door n put it to spin. Should work
May 27, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Frigidaire washer does not drain
Remove the drain hose from sink Unplug machine Safety 1st....put hose over bucket should gravity drain next take out the filter if its got one bottom /right hand side of machine clean...if not locate drain pump and remove blockage...kids sock maybe? Door may reset after water has been removed and unplugged .Good luck
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Machine only hums, will not spin, wash nor will the door open.
  • It sounds like the motor is spinning, but the drum is not spinning. This usually means the belt has broken, or come off of the pulley.
  • Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
  • Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
  • Broken wires at one of the out off balance switches or a bad switch itself.
  • A fairly common trouble maker has been a burnt diode on the main control board.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
  1. Remove the bezel from the soap/bleach/fabric softener dispenser.
  2. Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Feb 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Door lock doesn't release automatically; clothes still very wet
You need the Factory Repair Manual for your Affinity Washer. There is alot that can go wrong with these machines and you will need to run the washer through its diagnostics.
Here is a Link where you can Download the Affinity Washer Repair Manual
Thanks
Jan 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer
Check the filter located at the bottom left hand corner. There is a door that you can open and pull out the filter. Be prepared for a lot of water. Your door won't open if there is water in the tub
Mar 17, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
