Question about LG enV VX9900 Cellular Phone
My Envy 2 always says, "Battery Required" when I plug it in to the charger. How do I fix this?
Mine does that too, but i just let it stay like that and it charged it a bit so i guess i just wouldnt worry about it
Posted on Jan 21, 2010
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
Can i pair my kyocera ph.with HP ENVY 5530?
Probably can, try this: Remove your charger(phone) USB plug & plug it into your Envy if it has a USB. If you are on the internet it should go to Kyocera & download the program for your computer to make it usable. If your ENVY doesn't have a full USB you will have to get an adapter wire to connect them. Look at the USB plug on your ENVY. If you are trying to Bluetooth pair that is completely dependent on your Envy having Bluetooth.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Oct 24, 2014 | Computers & Internet
Plugged in but not charging
Hello, you need to check the charger if is really working or if turns on the laptop but is not charging then the battery is dead needs to be replaced.
Sep 25, 2013 | HP Envy Sleekbook 6
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
Dell inspiron 1525 pluged in not charging
Possible solutions:
Dec 02, 2012 | Dell Inspiron 1525 Notebook
My laptop not charging
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
My laptop won't charge when plugged in...I changed the charger but still won't charge
Or:
Possible solutions:
Or:
Feb 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
Should the onboard charger be plugged in 24/7?
I won't leave them on constantly. How about a timer for the onboard charger. Set it for 30 minutes a day. You get 3 1/2 hours a week and the batteries won't heat up.
Aug 06, 2009 | Boating
Using battery charger with 3.42A vs 4.74A for lap top
YOu can always use higher amps when required but not lower than required. Voltage should stay the same as original charger - keep it in mind.
Mar 02, 2009 | Acer Aspire 5100-3357 Notebook
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
382 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
