I need to bypass the lid lock sensor on a frigidaire fwx6970ew1 washer. What do I do?
    President:
  • 1,136 Answers
Hi, Remove the two screws in the lower front panel. Insert a flat blade screw driver into the gap between the top and front panel. There are two spring clips holding the top to the front panel. Once the top is raised, the front panel will push down and release.
The lid switch is located in the upper right hand corner attached to the side panel.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 27, 2009
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Jul 10, 2017 | Whirlpool Washing Machines
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
Can you by pass the lid switch
I appreciate your inquiry, friend!
Based off what you have described you would like to bypass the lid switch on your Frigidaire washer. It is not recommended to bypass this part. Doing so could lead to a fault within your washer. I hope this information is helpful. -Matt
Feb 13, 2015 | Frigidaire ATF7000ES Stackable Front Load...
Washer will not drain or turn on
You have a bad lid switch. It is usually just 2 wires which you can cut and splice together to bypass the switch. The motor on those runs the motor which spins the tub and pumps the water out, the lid switch is there to interrupt the motor if lid is opened. Now some of these models have a door lock incorporated into the switch as well. if that is the case here then you need to replace the whole switch/lock assembly.
Dec 11, 2013 | Frigidaire FEX831CS Top Load Stacked...
Lid lock bypass
Your "lid lock" really is an interlock to prevent machine operation when the lid is open. I use a plastic clothespin to close the interlock because the lid on my washer got bent
May 12, 2013 | Frigidaire Washing Machines
How do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Feb 18, 2013 | Amana Washing Machines
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Bypass the lid lock
how can i bypass the latch on a glass top washer ?
Jul 25, 2010 | Maytag Bravos MTW6600T Top Load Washer
How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Nov 28, 2008 | Admiral AAV7000A
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
