Panasonic CT-32D12D 32" TV
Problem for Panasonic CT-32D12D 32" TV
Our Panasonic tv is about 8 years old and will cut
By rgibson604 on Jun 27, 2009
Our Panasonic tv is about 8 years old and will cut off by itself and a few minutes later it will come back on. Some days it is worse than other days. Please advise what we need to do.
Thanks,
T. Gibson
Valley,AL
Comments:
Jun 27, 2009
- Thank you!
Solution #1
posted on Jun 27, 2009
Not Rated)
ronaldo_ross
Rank: Wiz
Rating: 84%, 292 votes
The first thing you can do is try plugging it somewhere else. Sometimes its the wall outlet. Unplug it and check to see if the plugs don't wiggle. Sometimes the metal plate on the plugs has broken loose. While it is plugged in move the cord to see if it does it. When all that don't determine the problem. You can open the TV, and check for loose connection, and cracked solder joints. Look aroun the flyback area because thats where most cracks develop because of its weight. I really don't recommend opening the TV because you could make the problem worse if you are not carefull. Also the tube can have lethal charge even if not plugged in, and some TV this charged remain for up to three days. Good luck.
Comments:
Jun 29, 2009
- You are welcome. Thanx for posting a question as well.
Was this helpful?
Yes
No
Popular Solutions for Panasonic CT-32D12D 32" TV
Questions and Unsolved Problems for Panasonic CT-32D12D 32" TV
Do you recommend Panasonic CT-32D12D 32" TV?
Answer
Answer
hd broadcasts fills whole screen. cuts off the sports ticker at top and bottom.
Answer
On initial turning on of TV no sound or horizontal hold for about a minute.
Answer
I have bought a SONY DVP-NS67P dvd player but lost the remote control. In order to get access to all... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic CT-32D12D 32" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
