Question about Toro Lawn Mower With Toro Power Tools
No spark toro 5 hp mower
5 hp toro mower has no spark.
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
  • 86 Answers
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
  • 376 Answers
SOURCE: Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
Posted on May 17, 2009
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
  • 127 Answers
SOURCE: Toro mower will not start
coil is breaking down under heat
Posted on Jul 26, 2009
6.5 toro self propel.....new plug and new gas,,,turns over but then shuts down...replaced both neoprene hoses
Carburetor Cleaning TUNE UP of Toro 6 5HP Lawnmower with Tecumseh Engine
The above link will provide a video on how to clean the carb on the 6.5 hp mower. Before you go to that length, try putting some carb cleaner in the fuel tank and see if that corrects the problem. Also, as the video shows, make sure the spark plug is getting a good spark. If the spark is weak , the fly wheel may be rusted, ot the magneto is bad.
May 09, 2014 | Garden
My lawn mower wont keep running, I have put on new spark plug, cleaned the carborator, changed the air filter. Any other ideas?
How thoroughly did you clean the carb? They need to be fully disassembled. There are some small orifices in them that need to be cleaned with either a jet cleaning tool or a piece of wire.
Aug 18, 2012 | Toro Lawn Mower With Toro Power Tools
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
Toro GTS5 5.5 HP will not start
after attempting to start a few times;remove the spark plug and, check it if it is wet the engine is flooding dry the plug and, reinsert prime once and, attempt to start
if the plug is dry check the fuel filter
ground the plug while starting to check for spark
Sep 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Toro mower does not strat
Did you possibly hit something? Sounds like the flywheel key may have sheared.
May 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
537 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
