Question about LG Dryers
My LG DLG5988W tumble dryer (gas) suddenly doesn't have any heat. I used it last a week ago and it worked fine. It tumbles and lights, etc are normal. The gas has not been turned off, the breakers haven't tripped. The drum was coated in water droplets when I opened it (which was beyond weird). Any ideas?
    President:
  • 3,085 Answers
You have a bad IGNITER ASSEMBLY. About $120.00 if you fix it yourself.
Posted on Dec 12, 2009
  • LG Master
  • 8,220 Answers
Dump the water container and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 27, 2009
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
My LG tumble dryer does not heat up, the motor runs and everything tumbles inside but it does not heat up. what could be the cause of this?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101\]]\]\
Aug 16, 2011 | Dryers
I have a LG (DLG0452W) gas dryer. It will tumble, but no heat. The light bars by the timer display are flashing orange instead of green. What could be the problem?
heatman101
Apr 27, 2011 | LG DLG0452W Gas Dryer
Dryer was working fine. Still runs, tumbles, etc, but all of a sudden, no heat. Only 2 yrs old. Cleaned vent and lint filter. Is it likely a hi limit switch (if so, can it be reset or does it need to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Samsung DV218AEW Electric Dryer
GAS LG DRYER TUMBLES BUT DOES NOT HEAT, WHAT COULD BE WRONG? CHECKED THE BREAKER AND GAS LINE, BOTH ARE ON AND GOOD.
Pilot light (flame) may have gone out..Dont know if you are on gas bottle or mains,if on bottle make sure not empty..most likely Pilot Light (flame).cheers
May 28, 2010 | LG DLG5932W Gas Dryer
Older Ge Hotpoint Dryer will tumble but not light the gas to heat
You state it is an older dryer, so I'd suggest replacement. The water may have damaged numerous components, including the motor, which would be costly to replace.
Aug 28, 2009 | Hotpoint NWSR483GBWW Gas Dryer
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Dry runs, but does not heat up
dude I just came here to find the same answer with my Maytag dryer! Just 10 seconds ago!
Apr 04, 2009 | Frigidaire GLGR331A Gas Dryer
CANNON GAS TUMBLE DRYEN NO HEAT SD10
heatman101
qerq
Feb 08, 2009 | LG DLG5988 Gas Dryer
Dryers Logo
448 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
