Question about Coleman Heating & Cooling
I need to fill my AC on my coleman pop up where is the hook up? its not on the top unit is it inside? Dan
  • Coleman Master
  • 8,220 Answers
It is probably just like a window unit. You is gonna have ta remove it from its hole and get the cover off. Probably put a line tap on it and shoot it with R22. If ye do not have a card ye cannot buy R22. Their ain't no sub you can buy.
Posted on Jun 27, 2009
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
We have a 1997 Coleman popup camper. The air is just a little cool and it keeps leaking on the inside. I called a repair place and was told it was most likely low in freon and that it could not be added...
the drain is blocked and needs a clean out ,look for a drain hole with a pipe to the outside .as for the gas recharge then yes it can be filled by a specialist and not a chancer ,you have to cut a pipe on the motor and solder a connection on the end not a problem for a experianced person
Jul 25, 2013 | Heating & Cooling
Coleman AC Tripping breaker
Fan motor is drawing too much current.
May 16, 2013 | Heating & Cooling
Need to add Heat strips to AC Unit
couple screws its simple they set in front of blower and plug in
Nov 20, 2009 | Coleman Heating & Cooling
Coleman Mach 3 ac unit tries to start compressor & kicks off
50 foot extention cord not a problem IF it is at least 10 gauge and plugged in to a 20 amp circuit
Your compressor is shutting down for a lack of AC voltage would be my best guess
Jul 27, 2009 | Coleman Mach III Air Conditioner
I am looking at a 94 Coleman pop up camper. The
They are a closed system, so obviously it had/has a leak. You can get some AC guys that will retrofit it to allow for adding freon, but if it has a leak anyway, which will probably cost you a couple of hundred bucks to find out you have a leak that may not be evident until after you've already bought it, then leaks out again, and your back at square one. Depending on what size BTU's you want, you can pay anywhere from $500-$1000 + plus inside controls etc, if needed.
Jul 10, 2009 | Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
