Question about Sony Cyber-Shot DSC-V1 Digital Camera
Memory stick error when camera is turned on
When the camera is turned on I keep getting a message saying memory stick error so I purchased a new one and I get the same message. It has a code flashing C 13;01
    Novelist:
  • 107 Answers
Hi
How about download the user manual from this link
http://www.docs.sony.com/release/DSCV1.pdf
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 27, 2009
  • M. Arsalan Jun 27, 2009
    Hi
    http://www.docs.sony.com/release/DSCV1.p...
I have Sony DSC-S40 camera with MS 1Gb, when i switch it on i have "access" then error message says" Memory stick error" and flashing "C:13:01" and I can't take photoes or...
Hello and Welcome to Fixya!
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope this solution helps you
Your token of appreciation in the form of four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 09, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Error message saying Reinsert memory stick
Buy a new card for the rest of the vacation, the new Sony cards come with free recovery software that may help recover the images on the old card?
Jun 02, 2010 | Sony Cybershot DSC-S950 Digital Camera
What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Apr 26, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
My sony keeps saying Reinsert the memory stick?
The error message "Reinsert Memory Stick" may occur due to the following reasons:
1. The inserted Memory Stick media is not supported for use with the Camera.
=Ensure you are using the supported type and capacity of Memory Stick media for use with the Camera.
Please click on the below link to check for the compatible Memory Sticks with the Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12
2. The terminals on the Memory Stick media are dirty.
=Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up.
3. The Memory Stick media is damaged.
=Use different Memory Stick media and check if the issue persists.
Mar 05, 2010 | Sony Cyber-shot DSC-W190 Digital Camera
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
Memory Stick Error
take wet cotton swab of alchohol and clean the terminals of memory stick.
Aug 06, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Memory full message in error
Remove some pictures from the memory stick Or copy them to your computer. Actually your memory stick is full. If you have no memory stick in the cam then purchase a new one for it. The cam memory is not enough to store many pictures.
Mar 28, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Memory Stick Error
Have you tried re-formatting the cards? If you can't with the camera you should be able to with a card reader. It's probably the camera, unfortunately, but this is worth a shot...
Sep 13, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony Cyber-Shot DSC-V1 Digital Camera Logo
209 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
