Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
I am having the same problem. Everything was working fine until one day I turned it off and on. Now I get no sound.
Same with me, one day just wouldn't work, it would intermittenly work but soon as i turn it off or watch for a long time just goes back to pcm digital and i can't get dolby back its frustrating.
