Question about Acer Aspire One A150-1006 Notebook
Acer aspire one is not starting up. It goes back to OS start up
Acer aspire one is not starting up. It gets to the windows xp startup and then immediately goes into a fault description that i can't see because it flashes away so fast and goes back to the selection screen for safe mode, safe mode with networking, safe mode with command prompt, last known good config. and start windows normally.
  • tegid28_2004 Jun 30, 2009
    I'm not able to get access to windows in any of the options. The system gives me a quick flash error in a blue screen then instantly goes back to the boot options menu to select safe mode and other such options as well as "last known good config". Hown can I stop it on the blue screen to see the error?
    Novelist:
  • 133 Answers
There are two possibilities i can think of, one, a virus, two, a bad driver file. what you can do, is run it in safe mode, if it goes to the log in screen, you could log in, and when a dialogue box appears to run in safe mode, click yes. then, go to the start menu, then locate my computer, right click on my computer, and click on manage. A window will pop up that says computer management on the top. In the middle, click on system tools, then device manager, and it will show a list of all of the devices that are installed. Lots of times, your display driver is updated and causes your computer to be unstable, there fore, giving you the bluescreen error, which causes your computer to constantly restart. (make sure all recently installed devices are unplugged before doing this. new devices may also cause this error). look for any devices with an exclamation point, right click, and uninstall them, then restart the computer to see if it solves your problem. if not, then it might be a virus that activates with internet acces, if so, run your computer in safe mode, and run a virus scan and hope that it finds the virus. If that doesn't work, then what i recommend is try to back up your work in a flash drive or disk and running the backup disc that comes with your computer. to run that, sometimes your computer comes with a disc, run that disc and follow the instructions. if not, then sometimes it comes preinstalled, and have to press f10 on the first boot screen. if none of those options are available, then call the manufacturer and ask for the restore disc for your computer model. Good luck
Posted on Jun 27, 2009
  • 430 Answers
Use last good config.....gl
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
Running xp and windows is corrupted. goes to blue screen and restarts after starting xp. will not start in safe mode. How do I get into it to repair windows
The OS disk has a repair feature built into it.
You just boot from the cd where the OS disk is placed and follow the directions when prompted.
Jan 07, 2010 | Acer Aspire 3610 Notebook
I have an acer aspire 5315 and on start up it goes to a screen about windows not starting up correctly gives option to start in safe mode, last known good configuration, and start normally. If I choose to...
This can be caused by a hardware failure (e.g. hard drive, etc.) or an operating system (OS) issue. Either way I would recommend taking it to a computer repair shop so they can diagnose the issue.
If its an OS issue most likely the cheapest way to fix it will be reloading the OS on a new hard drive(because its cheaper to buy a hard drive then have a company backup your data) then plug in your old hard drive to get access to your data.
Nov 12, 2009 | Acer Aspire 5315 Notebook
Won't start up
Try pressing F8 at start up. You get startup menu select save mode and see if it starts up.
Oct 02, 2008 | Acer Aspire 3680 Laptop
NOT booting WINDOW XP
Hey stanley154
try to boot your machine using window 98 startup disk or window 98 bootable CD. then type fdisk on DOS prompt. Then try to delete non dos partation and the create primary dos partation. Restart your machine, let it start window or the floppy until it return to dos prompt. Then you can type the format c: e.g a:\format c: or D:\format c:. After that try to run window xp.
all the best
zinja
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire laptop
Hi
OS means operating System and HDD stands for Hard Disk Drive.
When u turn ur system on is it already black or it shows the bootscreen like ACER logo etc. and then goes black.
If thats the case then ur OS has crashed. Try installing new one.
And if its black right from the start then i think it is a hardware failure.
In any case let me know.
Jun 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Startup problem
reinstalled your os..
Mar 18, 2008 | Acer Aspire 3680 Laptop
Acer aspire 3610 not booting pass flash screen
you can reinstall os with ur xp.
with xp disk in drive at startup do you get option to boot from cd.
if not go into bios at startup and enable cd boot in boot options as first;save and exit;restart.
I assume you know how to install windows(xp)
Mar 03, 2008 | Acer Aspire 3610 Notebook
START UP DISC FOR ACER ASPIRE 1640Z -
What operating System has been installed to your laptop?can you clarify it?you can download support software at ACER,com but startup disk is in windows xp CD or any windows os.you just configure your laptop in the CMOS setup or BIOS by accessing it on the boot up.just configure your laptop on CD/DVD boot media.
Jan 05, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire One A150-1006 Notebook Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
