Question about HP Pavilion dv6000z Notebook
Screen show no display/ only blank.
My screen is just blank. one minute fine,the next it went blank. i sent it off and when i got it back it worked for 2 days then bqack to the same.
  • HP Master
  • 32,281 Answers
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 27, 2009
XPS Gen2 / M170 display issue, mind boggling
What are the BIOS versions and what are the mother board revision numbers?
Mar 10, 2014 | Dell XPS M170 Notebook
Screen freezes and display faints
Hopefully the usb adapter just confused the battery. Did you use it this time or a regular plug? Its always best to fully discharge a battery and fully recharge it for the next use. They will lose life and malfunction otherwise. Glad you've had some luck, hopefully it will work just fine now.
Jun 02, 2009 | Garmin Forerunner 405 010-00658-20
Acer Aspire 5052 nothing on LCD
If the LCD display worked until the processor over heated and then went blank, and would work again once it cooled down, then yes I do. As you described above, the screen going blank and blank still on reboot ( no time to cool down ), then the next day the LCD displayed again ( cooled down over night ). Appears to be directly related to the over heating problem.
But if the display problem progressed to the point that the PC would boot up cold and the display was still blank, then I would think your graphics card will need repair.
Apr 20, 2009 | Acer Computers & Internet
Nokia n95 8gb
i think after all that you should replaced the mainboard
Oct 20, 2008 | Nokia N95 Cellular Phone
Nokia 6126 screen not showing
the problem is in display...better change ur display and use it...
Sep 19, 2008 | Nokia 6126 Cellular Phone
Blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
May 01, 2008 | Kyocera Oystr KX9 Cellular Phone
Toshiba 32" LCD video doesn't work anymore
Lamp has gone out, sounds like...accordianman
Feb 27, 2008 | Televison & Video
Different Problems
This is Phobos92.
It turned into the red ring of death. So no further help needed.
Feb 26, 2008 | Microsoft Xbox 360 Console
HP Pavilion dv6000z Notebook Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
