Question about Ovens
Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
The oven will only heat up to 150 degrees. It took about 1/2 hour to do that. It is getting gas & heat. The stove top is working fine. Why is my oven only heating up to 150 degrees & taking so long to do that?
  • abclark33 Jun 27, 2009
    It is lighting. It heats up to 150 degrees. The broiler works fine, just the baking part is giving me trouble.
  • 57 Answers
U sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Posted on Jun 27, 2009
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
My oven is loosing temperature
To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
Feb 10, 2012 | Ovens
Oven only heats to 150 degrees after 30 minutes.
Hi, this indeed sounds like an Thermostat or Thermistor sensor problem? This is the only real thing that can cause this problem usually.
You need to either obtain a service manual and troubleshoot the issue yourself, or get a "Quote" from a professional.
Jul 04, 2011 | Amana Ovens
Bosch gas oven heating slowly - takes about 1 hour to reach 150 - 200 degrees. When trays placed in oven, temperature decreases cooking very slowly
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 19, 2011 | Bosch HBL 5032 Electric Single Oven
Oven turns on, but w2ill only heat up to about 120 degrees, you can reset and increase temp, but will only go to 150 degrees. Broiler works, but oven anf d oven clean do not work
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 18, 2011 | Amana Ovens
My oven won't heat above 150 degrees. Is this is
this can be problem with the temp probe.and or the control board if your unit is equipped.
Jan 23, 2010 | Ovens
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Oven cuts out
Most of the time it is a temp sensor in the oven. We bought a service manual at houseneeds.com and fixed ours.
Nov 30, 2008 | Ovens
Oven gets too hot
Thermostat needs to be replaced.
Apr 10, 2008 | Ovens
Ovens Logo
420 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
