My washing machine has water coming out through the front, but no water coming out the back. Does that mean I need a new belt or is there something else wrong.
    President:
  • 1,136 Answers
HI, What make/model# is this so I can assist you further.
Vic
Posted on Jun 27, 2009
My Maytag A105 Washing Machine made a weird noise just as it started the spin cycle. When I opened the top lid, there was a burning smell and I could see some smoke coming out. I shut the lid again and...
This sounds like a belt burning. Something may have got caught in the pump and the belt is slipping and burning. You will need to drain all the water out first. Then remove the front panel. Tilt the machine back a little so you can reach the pump pulley and see if it turns freely. Your model has 2 belts and they both should be replaced at the same time. Adjustment on the pump belt is critical so the drive belt doesn't slip. If something is caught in the pump, whatever it is needs to be removed, or replace the pump.
Jan 03, 2010 | Maytag Washing Machines
Drum wont turn ,I think I over loaded it.Do I need a new belt ?
I took the back off and discovered the belt had come off rather than breaking .I put it back on making sure it lined up properly and the machine works fine now .
Dec 28, 2009 | Indesit W 123 Front Load Washer
I have frigidaire FWT449GFSI,the water can cont come out
HI, check the following to address this issue.
1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
My kenmore front load he2 plus wont drain.
2. Water Pump
Aug 05, 2009 | Kenmore HE2 Plus Front Load Washer
Front Loader will not drain or start...
HI, check the following to address this issue.(nd=no drain)
2. Water Pump
Jul 25, 2009 | Maytag MAH2400A Front Load Washer
My front load kenmore 417-44072300 wont agitate or spin
you have a belt broken, drain out the water and take the back of machine off and you will find the belt then go to a place that sellls appliance parts andget a new one
Jul 18, 2009 | Kenmore 43042 Front Load Washer
Stop in mid cycle
HD= No drain.
2. Water Pump
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Apr 23, 2009 | Electrolux Washing Machines
I have a GE front load washer model # whdvh626fww. it keeps making alot of noise when in the spin cycle and the belt keeps coming off. at first I thougt it was out of balance but that was not it . when I...
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Jul 19, 2008 | GE Washing Machines
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
