I am replacing my central A C. with a new one. I worked on Autos for 50 yrs. have guages. Do I Screw the Allen Plug in on the high side, run the compressor, then screw in the low side. to keep the r-22 in the condenser, and desolder the lines.
By George, you've got it.Front seat (screw in) the high side and run the unit. Do not let it pull into a vacuum as this will allow air to be sucked into the system when you open it. Also, watch you high side gage. Don't go over 400 psi. This is usually the High pressure cut out setting on most safeties. Pull low side to about 2-3 psi and kill unit. Let sit for about 5 minutes and then run it again back down to 2-3 psi. Front seat the low side any you should be good to go.
I strongly suggest that you add a filter/dryer to the system. It's good practice to do so once the system has been open. If you are going back with a 410-a system, don't leave it open to the atmosphere for more than 15 minutes. That is, the condensing unit. The only way to remove moisture from the oil on this system is to use filter/dryers. You can not vacuum it out like in the old days with R-12.
Good luck and hope this is what you are looking for.
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it...
(More)
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it possible to replace?
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when...
(More)
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when the air was warm to almost hot. Called the Hunter Fan tech line. We reset the thermostat and all was ok until about an hour ago when it started blowing warm air again. Need advice ASAP!
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS...
(More)
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS THAT
