Question about Dometic Rooftop RV Air Conditioner
When turning the fan on, it runs for about 10-20 mins then shuts down, same with the air conditioner. After it set for a few you can turn it on again and the same results.
  • 410 Answers
A loss of "freon" charge will cause a pressure sensor to shut the system down. Needs tested for amount of charge.
Posted on Jun 27, 2009
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
My colman rooftop ac unit shuts off after 5 min of use wait 5 more and you can turn it back on again when its running it works great its on a 1984 holiday rambler and has very low hours?
Try a new fan motor. It runs about $125.00, It will run a few min. then will trip the motor themal switch. you can probably still here the compressor running. It may also trip the breaker on shore power . good luck! the part you are looking for is a 1/3 hp 115vac 2 speed 1580/1020 rpm part number #1468-3069
Aug 25, 2010 | Coleman Mach III Air Conditioner
Fan on outdoor a/c unit not running
call in the technicians
compressor shutting down or power to the fan being interrupted causing the compressor to shut down
Jan 23, 2018 | Goodman CKL36AR36 Air Conditioner
Kenmore 12,000 BTU Room Air Conditioner ENERGY STAR
How many Square Feet is the ac rated for?How large of room are you trying to cool??
May 27, 2010 | Heating & Cooling
Shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
May 17, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
The fan stops running
check whether the power saver mode is on. put it off. or some timer must be on. stop the times. it wll be rectified
Jul 27, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Furnace burner turns off and on
The furnace is likely over heating and the high temp. safety is shutting it down. It then cools and starts again. Things to check: Filter, Blower wheel and indoor A/C coil. If any or all are dirty you are limiting air flow and need to clean them.
Jan 17, 2009 | Carrier 38CKC042 Air Conditioner
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Dometic Rooftop RV Air Conditioner Logo
91 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
