Question about HP LaserJet P3005n Printer
Problem prompt on DIMM error
Same Problem - 64MB onboard
16MB DIMM expansion
-Printer keeps crashing and needs to be restarted.
-Memory errors appear to be different every time the printer is restarted.
-The printer no longer gets to a ready state.
-Problem was progressively worse over a few months.
    Novelist:
  • 102 Answers
If the printer freezes or crashes at memory count or if the printer shows error Mem test failure replace DIMM or if the printer display is completely blank in that case obviuosly you can try reseating Mmeory Module.
However that doesn't fix the problem formatter board is faulty.
Need to get Formatter replaced.
Thanks and Regards
Neeraj Sharma
Posted on Jul 03, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
Sounds like a dud memory board to me. Make sure that the DIMM expansion is clipped firmly in and home, and then try again. Then try removing it completely and see whether the printer still crashes. If the printer works without the memory change the memory board.
Posted on Jun 27, 2009
HP color laserjet error code 49, we turn off the printer when it asks us to but still has an error on it. No clue what is wrong
From the HP Website
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter. Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Jul 15, 2011 | Office Equipment & Supplies
How to solve service error 49.00 in hp laserjet 2430dtn printer
49.XXXXX ERROR
A critical firmware error has occurred.
1. Press Cancel Job to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can
receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go
back to the first program and try printing a different file. If the message
appears only with a certain software program or print job, contact the
software vendor for assistance.
1. After performing the actions listed in the preceding item, if the message
persists when using different software programs and attempting specific print
jobs, disconnect all cables that connect the printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs and thirdparty solutions from the printer.
4. Remove all of the EIO devices from the printer.
5. Turn the printer on.
6. If the error message disappears, reinstall each DIMM, Compact Flash card, and EIO device one at a time, making sure to turn the printer off and then on again (booting to the Ready
prompt) as you install each device. To replace a DIMM, see Appendix D - Printer memory and expansion in the LaserJet 2400 Series User Guide.
7. Replace the DIMM or EIO device that caused the error message.
8. Remember to reconnect all of the cables that connect the printer to the
network or computer.
9. If the error message persists, reinstall the firmware with the latest possible firmware upgrade. Go to http:www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software.
Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
10. Replace the formatter
Feb 28, 2011 | HP LaserJet 2430dtn Printer
Printer will not print. keeps saying
first you pl. check the dimm/sdram module is seated properly in its place otherwise insert new one
Feb 05, 2010 | HP LaserJet P3005n Printer
HPLJ P3005x Error
8X.YYYY EMBEDDED JETDIRECT
ERROR
The HP Jetdirect embedded print server has
encountered a critical error.
● Turn the device off and then on.
● If the problem persists, contact
HP Support.
Sounds like it's more than memory failure.
Sep 17, 2009 | Office Equipment & Supplies
I CANNOT FORMAT AND INSTALL A NEW OS
You RAM module may be faulty or needs reseating in the DIMM slot B. Reseat the both RAM modules then :-
Check the POST information as it boots up, the amount of install RAM should equal to the installed RAM (the total RAM could be 256Mb or 512Mb or 1Gb depends how much memory you purchased with the laptop) less 64 Mb or 128 Mb RAM which is used for video memory (depends upon your video card requirements).
Once you fix your RAM problems you should be able to reinstall Windows.
Mar 04, 2009 | Dell Inspiron 1525 Notebook
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Jan 20, 2009 | HP LaserJet 4350dtn Printer
How we can share RAM memory with graphics memory of our PC?
all you have to do is go into the bios, do this by pressing F2 on boot up, when in the bios you need to look for "shared memory" or "graphics memory"
once you have chosen the shared memory you want save settings and exit by pressing F10, the pc will restart and the shared memory will be increased
regards
Nov 26, 2008 | Asrock P4I45GV R5 Motherboard
What Is The Max RAM Limit for a IBM ThinkPad 380XD?
From reviewing the manufacturers manual for that unit, I would have to agree that the maximum possible expansion memory you can install is 96mb. Here is the link to their users guide (pdf).
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/38xhmm.pdf
quote:
"Memory (Option) 2635-8xx/9xx/Axx/Bxx
Ÿ 8MB and 16MB 70ns EDO DIMM
card
Ÿ 16MB, 32MB, and 64MB EDO
DIMM card (max. 96MB)"
There you have it. Although unless you are able to find that specification of memory for cheap online, I would say it's not really worth it to invest in older ram with such slow bus speeds unless you definitely need it. Hope that helps.
May 01, 2008 | IBM ThinkPad 760 XL Notebook
Printer Problem
error occurred
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on.
3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter.
Mar 19, 2008 | Computers & Internet
Re: Bringing new life to Accient Acer Laptop (AAL) Extensa-367D
bios updete can do pto alimit it cannot convert 1.1 usb to 2 or support more memory . contact any service cenetr to get hel[ful advice and bios update
Oct 15, 2007 | Acer Extensa 367D Notebook
HP LaserJet P3005n Printer Logo
626 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
