Question about Garden
My dad gave me a push mower with a 4 hp Tecumseh. He says it takes a gas/oil mix, but it does have an oil reservoir and it won't start. Could this be a gas only engine? There are no mixed fuel stickers anywhere on this machine.
  • 376 Answers
It's a four cycle, gas only. Two cycle engines don't have a oil reservoir.
Posted on Jun 27, 2009
What fuel do I put into a Vantage 3.5 Tecumseh lawn mower?
If it has a place to add oil to the crank case, either a dip stick, or a filler opening at the bottom of the engine, then you just use regular gas. Be sure to verify that there is oil in the crank case before running it this way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jun 16, 2016 | Tecumseh Garden
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh 4.5 hp engine won't start
First thing to check on a Tecumseh; pull the half inch bowl nut (main jet) out of the bottom of the carburetor. Give it a good cleaning with carb cleaner then pay special attention to the teeny tiny hole that is right at the very top of the threads. It's so small you can hardly see it and if it clogs, your mower won't start. Best of luck to you.
Oct 29, 2011 | Mtd 22" Yard Machine Push Mower
Does the poulan p4tn20sa take a gas/oil mix?
I cannot find any literature on your mower, but I'm guessing it has a 4 stroke Brigg's engine on it. If so, then there is no gas/oil mix requirement. The only engine's where you mix gas and oil are 2 stroke engines, which are not installed on most of today's mowers. There should be a separate place on your mower to put gas and oil in. If so, then you should probably run straight 30 weight oil in it and do not overfill it or you'll ruin your engine. I hope this helps. James.
Jun 26, 2011 | Poulan "" Push Mower
I have MTD Yard machine and don't know if it is 2 or 4 cycle. Oil should be-SAE30. Can I use oil for 4-cycle which they soid me i Can. Tire.(M otomaster)
If your mower has seperate fill caps for the oil and the gasoline, then you have a 4 cycle or 4 stroke engine. In this case use SAE HD30 motor oil. If there is only 1 fill cap and it says oil & fuel mix, then you have a 2 cycle or 2 stroke engine.
Good luck
Sep 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My B&S Yard Machine shoots out white smoke it also leaks out oil and gas mixed
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
Good luck
roundo4
Sep 03, 2009 | Mtd 22" Yard Machine Push Mower
My lawnboy 10304 runs about one minute and shuts down. Any ideas?
It sounds like it is 2 stroke.
Carefully remove the carb bowl, by undoing the brass bolt.
Examine the brass bolt for a small pin-hole in the side.
Use a piece of corn-broom NEVER anything else !!! and poke the hole(S) to make sure they are clear.
Blow out with air if available.
You can use this method to clean out all the carb orifices carefully.
Hope it helps,
Andy.
Jun 15, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
