Home | Galileo | 720mm x 80mm Refractor Telescope | It will not focus. I h...
Galileo 720mm x 80mm Refractor Telescope
Problem for Galileo 720mm x 80mm Refractor Telescope
It will not focus. I have used several eyepieces
By themadinspec on Jun 27, 2009
It will not focus. I have used several eyepieces so either the 80 mm objective lense is defective, or the focuser is at the wrong distance.
Comments:
Jul 06, 2009
- I have used a 40 mm Plossl, a 25 mm Plossl, and a 12.5 mm Orthoscopic. All of these are quality eyepieces that work properly in my other telescopes. I did not use a barlow. Either the objective lense is defective or the focuser is in the wrong position. I can not find contact information for Galileo anywhere. At no time did I use a Barlow, nor did I mention it. What I need is the contact information for the manufacturer, not imaginary problems that do not exist.
Solution #1
posted on Jun 28, 2009
Somewhat Helpful)
Joe L
Rank: Guru  Binoculars & Telescopes  Expert
Rating: 89%, 219 votes
It WILL focus -- put the eyepiece with the LARGEST number in it into the tube........... DO NOT USE the 2x or 3x Barlow.......... this eyepiece is the LOWEST magnification.
Take the scope outside during the day and practice focusing on a distant object at least 100 yards away. If you are expecting 650 power forget it-- you will only get about 120 power as the maximum usable magnification, with that aperture 80mm scope.
Was this helpful?
Yes
No
Solution #2
posted on Sep 16, 2009
Not Rated)
dadoh
Rank: Apprentice  Binoculars & Telescopes  Expert
Rating: 0%, 0 votes
you need to use that flip barlow as a spacer to reach focus
Was this helpful?
Yes
No
Solution #3
posted on Aug 01, 2009
Not Rated)
cappy1964
Rank: Wiz  Binoculars & Telescopes  Expert
Rating: 79%, 19 votes
Yes, I did type mirror/s I know....Your problem still could be that the lenses need collimating....just thought that I should pick up on my own mistake. Cheers.
Was this helpful?
Yes
No
Solution #4
Not Rated)
cappy1964
It sounds to me like your mirror/s need collimating. It might be worth getting in touch with your local astronomical society. They will probably have someone onboard that will have a collimator and what's more they'll show you how to use it. It would be silly to buy a piece of equipment like that for one use, on the chance that that is your problem. Most societies have a "public night" call or email them and then take it along. I have no doubt that they will be glad to help. Hope you get some satisfaction!
Was this helpful?
Yes
No
Popular Solutions for Galileo 720mm x 80mm Refractor
Questions and Unsolved Problems for Galileo 720mm x 80mm Refractor
Do you recommend Galileo 720mm x 80mm Refractor Telescope?
Answer
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and battery number for a Tasco red dot Propoint PDP2
Answer
What is the voltage and number of the battery for a Tasco red dot Propoint PDP2
Answer
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or... (More)
Answer
I would like to find an instruction manual for this telescope. Any ideas where to look? Want to... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Galileo 720mm x 80mm Refractor...:
Top Telescope Experts
Rank: Guru Guru
Solutions: 610
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
