Question about Char-Broil Grilling
I just assembled my charbroil model 46361009. I
I just assembled my charbroil model 46361009. I had only one problem with assembly, the ignitor wire does not fit over the ignitor button spark part. When I placed the ignitor wire over the spark part, it lit with no problem, only the ignitor wire immediately falls off and is no longer connected. I'm not sure where exactly it should be connected, but when I put it over the metal part of the end of the ignitor switch, it lit the grill. I don't know if this is right, or if the wire is too small, the ignitor switch too big???? Help
SOURCE: ducane grill ignitor replacement
buy a new grill?
Posted on Aug 06, 2008
SOURCE: I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Posted on Apr 09, 2009
SOURCE: Grill heats up at first than will not get hotter that 350 degrees
how make need icecam2 open video ask
Posted on May 20, 2009
  • 51 Answers
SOURCE: i don't mave instructions on how to assemble my grill
use your brain
Posted on Sep 04, 2009
bulldogchief
  • 388 Answers
SOURCE: I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Posted on Sep 07, 2009
Purchased model 463621611 and lost the assembly instruction manual. please email new one.
Here are 2 links (Part A & part B) of Owner's Assembly Manual you need. You can download and print then for future reference.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/4293a_110502_0.pdf
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/4293b_110502_0.pdf
Hope this helps you. Happy Grilling and thanks for choosing FixYa.
Sep 17, 2011 | Char-Broil CharBroil 4637318 Grill
Assembly instructions for char broil lp gas barbecue grill 463730807
try this link http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%20463730807_2.pdf if you need anything else or this is not what you need please contact me and i will help.
Thank you.
this is the manufacture web site in case you may need them. http://www.charbroil.com/ProductSupport/463730807/2007-CharBroil-Gas-Grills.aspx
Jun 26, 2011 | Garden
Dryer is not heating. where is the heat sensor on DLE5001W
On a gas dryer the gas assembly is simply powered up by a sensor on the blower housing. If heat is called for from upstairs the power flows through the bimetal mounted on the blower housing. Here is a simple bi-metal: themobilian_2460.jpg
See the 4 wires? 2 of them wires operate a small heater inside the control. when it gets heated it shuts down faster for permapress and knits. Next to the control is a fuse on most models as seen here:
That fuse blows if the air temp exceeds 350f. That control thermostat at its hottest setting of cotton shuts down at 160f. It ramps back up at 105f. and continues to send power to the gas assembly till it feels 160f and then it shuts down. SOOO.. if we have a good fuse and a good thermostat 120 volts should get to the gas assembly if heat is needed. The gas assembly has a flame sensor which detects the heat bouncing off the ignitor. An ignitor to light off the gas, and a pair of holding coils. The whole gas assembly is energized at one. But them coils will not supply gas until the ignitor drops out if the circuit. To do so the flame sensor bi metal must shut down the power to the ignitor and that frees up the power to charge them coils and yank open the valve. The gas hits the ignitor and whoosh we have fire in the hole. It takes literally no time for the temp to reach 160 in the blower housing and so the power is removed from the gas assembly and the dryer tumbles onward absorbing the heat till the temp drops down to 105f and that control once again powers up the gas assembly. If your flame sensor is working and shutting down the ignitor and the heat works once or twice but quits then them solenoids are getting hot and quitting because they are old and weak. Replace em and party on.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2011 | Whirlpool LGQ8000JQ Gas Dryer
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Where do you hook up the sideburner ignitor wire to on the char-coil bbq model 463721111
The side burner ignitor wire connects to the spare lug on the main ignitior module. That one module, controls all the spark ignitors at each main burner and the side burner. When you press the button all ignitors spark at one time. I know it sounds stupid, but that's the way Charbroil's R & D designed it. I guess it saves money.
Hope this helped you to make the final hookup. Happy Grilling!!
May 01, 2011 | Char-Broil CharBroil 4637318 Grill
Need to know where to connect igniter button to where side burner is still connected not main burners
According to your Owners Manual, the side burner uses the same electronic ignitor as the main burners. I know that sounds odd, but that's what Charbroil often does with their igrills.
To help you with further insight and in case you've misplaced your Owners/Assembly Manual, I have included a link to it that you can download and print for future reference, if you like.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Happy Grilling!!
Apr 23, 2011 | Char-Broil Advantage 463453306
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
Grilling Logo
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
