Washer is leaking out the bottom but hoses are fine
    President:
  • 1,136 Answers
HI, What make/model# is this washer. It could be a pump leaking.
Please let me know so I can assist you further.
Vic
Posted on Jun 27, 2009
My washer runs fine and drains fine but leaks water from the drainage hose. Is the connection just not secure enough or is there a problem with the pump?
if its leaking from the center bottom front of unit its your pump..if its leaking farther back it could be the hose...take a peice of news paper and stick it under front of unit,,it will give you a good idea,,if you need a closer look and help openning cabnit,repost.. good luck
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Leaking from bottom as soon as washer fills
I would request you to pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Thank You for contacting Fixya.com
Aug 03, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Water leak from bottom
then you may be leaking from the water pump. maybe is worn out, only way to find it is to remove the cabinet an do a load test an see if it comes from there, if the hoses are fine then check the pump.
May 13, 2009 | Maytag LAT3600A Top Load Washer
GE top load washer leaks out of bottom only when filled over half
there is a hose on the bottom it is a manufacture defect. hose is like 8 bucks lasts good yr
Feb 28, 2009 | GE WBSR3140D Top Load Washer
How can I fix my Kenmore portable washer 100.49722990?
Most common cause for water leak
is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
