Question about Dryers
I can't get to the drive belt on my dryer. It
I can't get to the drive belt on my dryer. It snapped off and I can't get the ''lid'' off to repair it.
  • jmdeck75 Jun 27, 2009
    GE
    Model #DDE8200SAMAA
    President:
  • 1,136 Answers
What make/model# is this dryer?
I can help you. Please let me know.
Vic
Posted on Jun 27, 2009
  • Victor
    Victor Jun 28, 2009
    Remove the rear access panel. If the belt is not boke, move the spring loaded idler pulley to the left with one hand and then put the belt on the motor pulley making sure the rib side of the belt touches the ,otor pulley. Let the idler pulley rest against the back/flat side of the belt.
    I hope this helps you
    If the belt is broke and you need help getting it over the drum, let me know.
    Please let me know if I can assist you further.
    Vic
Whirlpool dryer model WED5500XW heats up but drum will not spin. Belt is still on the drum. Any ideas what to look for
Hello Betty Lue Sydnor...
Great question! Better detail...
The Belt is still on... it is either your drive pulley or the tension pulley... has come loose.
If you watch the attached video... all will come clear...
This looks to be a fairly cumbersome job... but if you snap pictures
as you go you will be able to put everything exactly back where it needs to be to work...
Watch these videos.
http://www.appliancepartspros.com/whirlpool-dryer-repair-kit-4392067-ap3109602.html#autoplay
Idler Pulley with Tri Ring and Gasket
Whirlpool 661570V Drive Belt PartSelect
Aug 17, 2016 | Whirlpool Dryers
My dryer won't spin anymore. It runs on, and there is heat, but won't spin? How can I fix it?
Remove the plug to be safe. Look around the top cover, find the screws that hold it, remove them, lift the lid and see if the drive belt has snapped. There maybe an access panel on the rear whereby you can see the belt?
When you call your local appliance shop have all the details to hand from the plate on the rear.
Nov 28, 2015 | Washing Machines
Drum not spinning on my indisit dryer
If the dryer has a belt fitted it may have come off or snapped, remove the lid or look underneath and you may see a broken belt.
If not belt driven the brushes in the motor may need replacing if they ahve worn.
Dec 29, 2012 | Dryers
Dryer has power. control lights working. when you press the start button the only sound is a humming noise. will not start.
Check your drive belt which is located around the outside of the drum. The "hummmm" you hear sounds like the motor running. Normaly this motor provides the power to the belt which surrounds the outer surface of the drum (where u put the cloths)........ the belt wraps around the outside of the drum, then around a small pully mounted on the shaft of an electrical motor normally located just below the drum on the inside of the outer enclosure. This motor will be mounted to the the dryer's frame by a mounting plate. This motor mounting plate will pivot (like a hinge)..... it will also have an extension spring hooked to it which provides tension to the drive belt when properly looped around the pulley on the drive motor. When the belt breaks or snaps....... the drum stops spinning..... however the drive motor still runs. Thats the noise you hear! Diss-assemble outer sheet metal providing access to drive belt and replace with correct belt recommended for your model dryer. Caution should be used during repair........ ALWAYS UNPLUG POWER CORD PRIOR TO SERVICING ALL/ANY APPLIANCE's !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 14, 2011 | Frigidaire AEQ8000FG Dryer
MY BENDIX BIM145W WASHER WON'T WORK. WHEN IT'S SWITCHED ON IT MAKES A WHIRRING SOUND FOR A FEW SECONDS AND THEN NOTHING. WOULD THIS BE AN EXPENSIVE REPAIR.
sounds like your belt has come off or snapped. Remove the back panel and look to see if the belt is snapped. If there is no panel to remove then take the lid off and look at the back to see if the belt is off, if it is it should be underneath the machine. Hope this helps
Feb 28, 2011 | Tricity Bendix Dryers
Maytag MDG2300BWW dryer drum stopped turning. We can feel the heat and the motor but the drum doesnt rotate. Is this the belt?
Yes it will probably be the belt that has snapped, afraid they can be quite a job to replace as you have to take the drum out of the appliance to get the new belt around the drum. Although it also could be your motor if this has failed it may make a nois but not have th power to turn the drum.
You can open the appliance up by using flat head screwdriver at either end of the lid pushing it into the gap between the frame and the lid and prising it upwards and the top will pop up and you will then be able to see if the belt has snapped
Nov 04, 2010 | Maytag MDG2300BWW Electric Dryer
How do you open the dryer to fix the belt
First before you you raise the top, open the cover on the back by the motor and let the belt loose from the motor pulley unless the belt has broken. If it has go to the lid. Slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. Three are usually two screws, one on each side holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on.
Jun 06, 2009 | Maytag MDG6000 Dryer
Indesit IS 60 VS
You may want to get some assistance here. Purchase a belt from an appliance store and your help put it on. It is not hard and should not take more than 30 minutes. Take the old belt with you and the model number so it can be matched up.
Jul 01, 2008 | Maytag PYE2300AY Electric Dryer
Roper dryer
Hi Stefan71, The lid or top part of the dry is just snapped together with clips. All you do is pry up on the lid like a hood on a car. it will pop free and tadah, theres your belt. You do need to look at the rollers for something on them, The thump is more than likely coming from the rollers . Hope this helps
Sep 19, 2007 | Roper REX4634KQ Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
Marvin
Marvin
