Question about Garden
Have a mcCulloch eletric 300s, it runs slow and trips the breaker.
  • 10,865 Answers
Hello. If it is tripping the breaker you will have to use a shorter extension cord, or a heavier extension cord. A brief electrical note - most residential circuits are 15 amps. There fore, go to the hardware store and get a 15 amp or even a 20 amp extension cord. This will solve your problem as long as you don't have lots of other appliances drawing on the circuit you are using. A blow dryer for instance, uses a lot of amperage, as does a microwave. Try to use a circuit that is dedicated to your chain saw for the length of time you are using it.
Posted on Jun 27, 2009
Circuit breaker trips out
What is the rating of the breaker? Is this enough to run the saw? If this is ok, has the motor become damaged or has the blade got dirt or wood dust slowing it down?
Jul 25, 2014 | Hitachi C10FR 10" Job-Site Table Saw 15...
I have a 5kw generator it was working fine I use it on the oil fields to power my little rv suddenly every time I turn on the air con it trips the breaker and now im using a air compressor and at first...
A number of things can cause this. A sit worked before !
Basically:
Engines get older and can't hold HP which causes the rpm to slow and voltage dip, this causes a current increase and trips.
Breakers also get weaker especially if they trip a few times
HVAC and compressors pull approx 6 times the current to start as they do to run, once they have run a while, they build up higher head pressures which cause harder starting and more current draw, hence the breaker tripping.
It's hard to pin point which is the actual issue, but these all contribute.
Aug 08, 2013 | Briggs & Stratton Power Products 5,550...
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
Oct 31, 2012 | Electrical Supplies
When switchin on cooker it trips back off
make sure your electricity lines aren't connected to the ground(wire) on your oven
May 09, 2012 | Crock Pots & Slow Cookers
Trips breaker
You could have a dirty condenser coil or the fan motor isn't running at the proper speed to slow, weak or bad breaker, breaker to small causing to much voltage drop, loose plug in connection at wall outlet.
Jun 29, 2010 | Whirlpool ACQ128 Air Conditioner
I need to replace the power cord on the poulan es300 and the case does not come apart very easily
There is 1 other 300S model , do not it is significantly different.
http://www.ordertree.com/modelinfo/MCC/300S-14-07%2F93-to-05%2F96-IPL-211789/139.300S-14-07%2F93-to-05%2F96-IPL-211789.1.59.1.html
I recommend you open the attached IPL (300S-14) and use it as a disassembly/reassembly guide. I think the "General Assembly" print has the detail you need. If it were my project I might snap some photos as things progress just to refresh my memory when putting it all back together.
All saws can be found here (Alpha Numeric order; yours - right column about halfway down):
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
Good Luck. If I be of additional help please reply below. HTH
Lou
Feb 23, 2010 | Poulan ES350 16" Chain Saw
After running any eletrical equipment for +- half an hour ie fire or power tool,in the house I am renovating the main incommer switch continually trips,but no other circuit breakers do,please can you give...
The main breaker MAY be defective.
MORE likely is that certain main bus electrical connections within the panel are loose and overheating. This heat can trip the main breaker. Once the heating has occured at a connection, USUALLY the plating of the connection is burned and the whole thing needs replacing.
There is usually evidence of overheating such as discoloration.
IF THIS HEATING HAS OCCURED have the repair done immediately as it is a major fire hazard.
Nov 10, 2009 | Electrical Supplies
Is there a reset button after heating up and
Not sure about your model.
Look on the motor, sometimes there is a reset button on the motor.
Sep 25, 2009 | Whirlpool LER4634J Electric Dryer
Need an owner manual for mcculloch eager ****** 300s-16 electric chain saw. Already contacted mcculloch and their parent company and the manual is not available from them
You would pay the manual about the price of new saw. These are made in china and usually motor or the switch blows. Check that the voltage pass thru the switch and if so and it dont work, throw it away.
Aug 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Replacing eletric portion of Coleman PMA525500
my voltage meter shows 300volts instead of 230-240 and continues to trip generator breaker. What is my problem?
Sep 06, 2008 | Coleman Powermate Powermate 5000W...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
