Question about Malber P21 Front Load Washer
How to install a new dryer belt in a newer moffat dryer
How do i install a belt on my moffat dryer model # ruxr453ev1ww
Posted on Apr 11, 2011
How do I take apart Moffat Dryer Model RVSR363EH7WW
It is very easy ,just lift top and remove front and pull drum out of dryer and do reverse to put them back
Feb 26, 2015 | Dryers
Moffat stove don't have power on one side front and back I have changed fuse and new prongs
Check Breakers in your Fuse Box. sounds like it's running on 120 when it should be 240
Dec 14, 2014 | Dryers
Moffat Dryer, when I press the Start button, it works fine but if I release it does not run at all
The motor was the expensive part. I would have checked the switch first. If its on when you hold it buttndoesnt stat on when you let go then its most likely the switch that button engages is not staying seated and pops out instead of waiting for the signal at the end of the cycle. If its a newer and under warranty dryer then warranty it out but since I'm guessing its not, weigh the cost of a new one vs paying some company to fix it. You may be able to find a replacement switch online like eBay. This would not be to hard to change out.
Dec 07, 2014 | Dryers
Replace a belt on indesit dryer
Hello.
Tools needed to solve the problem
(A)Standard screwdriver,New belt
1 Unplug your dryer to disconnect power to the unit.
2 Remove the screws that hold the dryer top in place using a standard screwdriver. The screws are located along the top and sides of the dryer. With older models -- 1996 and older -- the entire top comes off the dryer. For new models, the timer and console stay in place while the rest of the top comes off.
3 Remove the screws that hold the front panel and door in place using a standard screwdriver. The screws are just inside the door at the top front left and right sides of the dryer. The front panel on older models will move to the right side and on newer models the door will move to the left.
4 Remove the existing belt by pulling the idler pulley to the right. This will take the tension off the belt and allow you to pull it away from the motor pulley.
5 Install the new dryer belt by wrapping it around the top of the drum and allowing it to fall around the circumference of the drum. The grooves of the new belt should face down toward the drum. Rotate the belt around the drum to ensure there are no twists in it.
6 Connect the new belt to the motor pulley. On newer models you can access the motor pulley on the front underneath side of the dryer. Pull the idler pulley to the right and loop the belt around it. On older models you can access the motor pulley through an access panel on the back of the dryer. Pull the dryer away from the wall and remove the access panel using a standard screwdriver. Repeat the same steps as on a newer dryer to install the belt around the motor and idler pulleys.
7 Replace the front panel of the dryer and the screws that hold it in place.
8 Replace the top of the dryer and the screws that hold it in place.
9 Plug the dryer in and make sure the belt works properly before trying to use the unit.
Thanks.
Nov 07, 2011 | Indesit W 123 Front Load Washer
I have a moffat dryer and the drum won't turn, but the motor seems to hum like normal.
You probably have a broken belt that goes from the motor to the drum
Aug 19, 2010 | Dryers
MOFFAT PLATINUM MOD# rwxr463etoww, SER#tm7o2962a DRYER WILL SHUT IS SELF OFF AFTER 10MIN. OF OPPERATION. LOUD NOISE FROM TURN ON SWITCH BEFORE UNIT STAYS ON FOR TEN MIN THEN SHUTS OFF. CHECKED...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Motor is burning up internally...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2010 | Dryers
I need to replace the front seal on the drum of my Moffat dryer (model # RCKH315EHWW, and am wondering if that is something that I would be able to do myself? Or, how much can I expect in labour? I already...
The drum gasket is WE9M26. To install it, it is the biggest job compared to any dryer gasket of hundreds of dryers that I have worked on.
See RCKH315EH0WW at:
http://partsnet.geappliances.ca
In summary:
-Remove top
-Remove console (some plugs require a tiny screwdriver to pry off. Do not pull on the plugs too hard.)
-Unscrew front panel (some screws are on the front of the bottom panel. Do not remove yet)
-Remove both side panels (cut off zip ties)
-Remove front panel
-Remove air director (big white plastic part)
-Do NOT remove drum. The belt is too difficult to reinstall.
-Apply contact cement in the groove in the air director. Install new gasket.
-When reassembling, line up the duct with the rectangular groove in the air director.
Good luck and congrats if you succeed!
Jan 20, 2010 | GE Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Need to replace the belt on a moffat clothes dryer, model md777lw449
I took the model number of the dryer to a supplier (Amre supply Hamilton On), they sold me the belt. I found replacment instructions on the web and did the job myself.
Nov 20, 2008 | Dryers
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Sep 18, 2008 | Maytag Dryers
Malber P21 Front Load Washer Logo
781 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
