Question about Sony PlayStation Portable (PSP) Console
My psp doesn't not turn on
My psp does not turn on only four 5 or 8 seconds but then i can't enter the recovery menu when i hold (R) while turing on my psp , my friend Said it was bricked . so help me it been one month is thier a way without pandora BATTERY .
  • 5 Answers
Sorry... its brick....
Posted on Jun 27, 2009
The angry birds for psp does not run and shows problem/error 80020148
Is your game in a memory stick?
Try this:
1. Goto Recovery Menu (turn off then hold R and turn on)
2. Configuration -> Use NO-UMD (Disable it)
3. Go all the way back to main menu
4. Advanced -> Advanced Configuration -> (Disable all of them)
If that doesn't work, update me before rating my answer, so I can advice another solution.
Aug 20, 2011 | Sony PlayStation Portable (PSP) Console
Tip
Play psp games on tv via composite/component av cable
you will need to have:
1.a psp slim with custom firmware 3.80 or 3.90.
2.composite/component av cable.
3.installer plugin file FUSA that can be sourced in the internet e.g. qj.net.
4.memory stick pro duo with 2 gigabytes capacity.
steps:
1.source the FUSA installer file.
2.once sourced,extract it to your pc desktop using 'winrar'.
3.connect pc to psp via usb.
4.upon extraction,copy or drag all four files (prx and txt) to the 'seplugins' folder on the memory stick (ms0:/seplugins/).
5.if you don't have the 'seplugins' folder on the root of the memory stick,create it.
6.exit usb connection and completely turn off psp,then turn it back on while pressing the 'R' button to go to recovery menu.
7.on recovery menu,choose and click plugins,set the FUSA plugin to 'enable',then exit recovery menu.
8.you can also activate the plugin on the FUSA menu itself,and this is better recommended.
9.connect now psp to crt tv using component av cable.
10.load a game and after loading it,just right before clicking the 'start' button to begin play,exactly at this point,simultaneously press on the volume - and + buttons to bring out the FUSA menu.
11.after a few seconds,the FUSA menu will appear on the psp screen,change the settings accordingly,exit FUSA menu and start the game to play it on your tv.
*many games or emulators will work but not all as the FUSA file is still in its beta stage,you need to figure out which one will work or not through trial and error.use caution,this guide works but no guarantees.
*used a 2 gb memory stick pro duo as 4 gb didn't work.
*used on an interlace only tv and not progressive or crt/non-flat/lcd/plastma/hdtv's.
thanks.
on May 05, 2008 | Sony PlayStation Portable (PSP) Console
My psp got switched off when i formatted. when i switch on, it shows a blank screen. please help!
I guess we have a BRICKED PSP here.
Well, if you got a PSP Board that can be recovered from bricking, try doing this;
1. Totally turn off your PSP by removing your battery and putting it back. 2. Press and Hold "R" button while switching your PSP on. 3. If Recovery Menu appears, click the recovery boot option.
If there is no Recovery Menu, your second option is to try Unbricking your PSP using PANDORA Battery and a Magic Memory Stick.
May 20, 2011 | Video Game Consoles & Games
How to go to recovery menu psp 3004 v5.03 m33-6
Press Hold Triangle Square Select Start at The Same Time and the Power Button and you should see the initial setup;and then you can recover the settings of your PSP :) ,hope it'll work ;)
Dec 01, 2009 | Sony PlayStation Portable (PSP) Console
THE GAME COULD NOT BE STARTED(80020148)
Recovery menu is located by doing this process...Turn off your psp completely. Then hold the R button while the psp is off. Keep holding the R button and turn on your psp. Then it brings you to the recovery menu
Jun 01, 2009 | Sony PSP (Piano Black)
How do we find the recovery menu on sony psp piano black
For the recovery menu turn on your psp then hold the off button until it turns off itself then let go of the off button, now hold down the right trigger and at the same time turn the psp on then you should have the recovery menu.
Apr 22, 2009 | Sony PSP (Piano Black)
Psp
Um your best bet if your psp has CustomFirmWare. Just go into the recovery menu. From a cold start hold the r trigger down then turn on the power button. From there you should see the recovery menu. From there you have a couple of options. You can recover to an OFW psp or try to repair what damage has been done. But if I may ask, are you putting the music in the right folder? HAve to reformated your memory stick after having a CFW?
Jan 25, 2009 | Video Game Consoles & Games
Sony PSP Theme Help
Make a theme folder called
THEME
all caps
put it in the PSP folder, so the outcome will be
PSP/THEME
Feb 28, 2008 | Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Feb 06, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
169 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
