Question about Danby DPAC8020 Air Conditioner
Can the air conditioner be recharged - Danby DPAC8020 Air Conditioner
Yes it sure can. As with cars air con units lose its charge over time. depending on how old the unit is if its still serviceable you need to get a professional to recharge it for you
Posted on Jun 27, 2009
How do I recharge unit
call a service repairman probably needs the recharge fitting added as they do not come from factory with them on
Jul 20, 2015 | Amana 14,000 BTU Portable Air Conditioner...
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
Can a fedders air conditioner A7Y15F2A-E be recharged?
Hello, anytime the unit does not blow out cool air I like to start with checking the airflow, check the filter and the evaporator coil for a buildup of dirt. If that check out ok then either the unit has a refrigerant leak or the compressor is not operating if the compressor is running than the unit is low on refrigersnt and can be recharged. In order to recharge the unit a piercing valve must be installed on the low side of the system, most window units do not have valves so one must be added to be able to charge the unit.
Jun 29, 2012 | Fedders X Chassis A6X08F2A Air Conditioner
Want to recharge my wg5000 air conditioner
Hello, in order to recharge the unit you will have to add a piercing valve to the low side of the system and add the refrigerant in.
May 13, 2012 | Goldstar WG5000 Air Conditioner
My air conditioner is 8 years old and no longer cooling the air that well. I always clean the filter. Is there a way to recharge or add freon to the unit?
Yes, it can be recharged. But, due to equipment that is required to do this, it's best left to the pros. Especially, since there are EPA requirements that have to be met, when evacuating the system, prior to recharging it.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Maytag M6Q10F2A Air Conditioner
Can I recharge my rooftop Dometic air conditioner?
Yes they can be recharged, but it takes specialized equipment to do it right...it also takes a bit of experience to know when you have it right also...
I would definetly recommend that you call a professional to do the job...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 16, 2010 | Dometic Rooftop RV Air Conditioner
Can it be recharged?
Yes it can be recharged... but the leak will also have to be found and all that may cost more then it is worth...
Here is a tip about trouble shooting your air conditioner...
heatman101
Aug 07, 2010 | Maytag Electronic Portable Air Conditioner...
Needs coolant and recharge
your best bet is to look in the yellow pages under air conditioner repair. With the new laws regarding the use of refrigerants you are supposed to be licensed to work with these substances yourself. Also, you need special tools to recharge an airconditioner which would cost you a lot more than a servicing. Joe
Jun 07, 2010 | Fujitronic FA1400 Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
Window Air Conditioner
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Sep 06, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Danby DPAC8020 Air Conditioner Logo
425 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
