Question about HP Pavilion dv1000 Notebook
Vertical Panels on the screen
I have a HP Pavilion dv1330. Over the last couple of days I have had vertical panels (blocks) on the screen measuring about 4 cms wide. about 3.5cm was white and about 0.5cm was red. There were about 5 vertical panels across the screen. Each panel had horizontal lines on it.
The laptop wouldnt let me shut down by control alt del or even by turning off the button, so I had to remove the battery.
I recall it happened in screen saver mode.
Seems OK at the moment though.
    Novelist:
  • 85 Answers
If it goes away after a reboot it is very likely a video driver or video software layer problem. If it only does it coming off screen saver mode, sounds like your screen saver has become corrupt - try another or reinstall the one you are using. Otherwise, try to reinstall new drivers for the video card, and update the to latest version of DirectX.
Good luck...
Posted on Nov 16, 2007
Getting colored vertical lines on the screen of my hp pavilion dv9000. I've come across this a couple of times and was able to fix it by pc recovery. Not this time. I'm getting the virtical colored lines...
Typically you are looking at a hardware problem here. Vertical lines typically indicates there's interference in the video stream received on the display, or a problem with the panel itself. You might be able to open the device and try to reseat the ribbon, but you risk destroying the device in the process if you don't know what you're doing.
Nov 15, 2017 | HP Pavilion dv9000 Motherboard
A vertical black line about 2/3 cms wide on the left of the screen has just appeared.
This can be a dirty ribbon cable on the lower right buffer board. I don't suggest you attempt this procedure. It can also be a defective display. I highly recommend having it looked at by a professional.
Nov 26, 2010 | LG 42PX5D 42 in. Plasma HDTV
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Vertical thin linings on lcd monitor
pull out your memory sticks and reboot with one of the two. if you nonly have one barrow one from some one else
Dec 30, 2007 | HP Pavilion dv4000 Notebook
Samsumg plasma tv 42
it sounds like the panel is bad..if it is less then a year old you should contact samsung
Nov 08, 2007 | Samsung HP-S4253 Television
Display
It could be a bad screen, but I'd suggest checking the screen cable connector (unplug and reseat it a couple of times). Also, check for any breaks, wear or fraying on the screen cable.
Have a super day!
R-
Nov 05, 2007 | HP Pavilion zd8000 Notebook
A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Aug 16, 2006 | Samsung PPM50H2 50 in. Plasma Television
HP Pavilion dv1000 Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
