Question about Dell Latitude D800 Notebook
No video on my dell latitiude d800
My laptop when power up only works sometime
i change the memory to another slot and same problem. i baught a new memory and same video problem im getting
i went to a technian and he says that my laptop has a video card and it is damaged thats why i am having this problem. but i dont think its the video card cause the system comes on a couple of days. so please assist me if u can.
  • Dell Master
  • 32,281 Answers
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 27, 2009
Shows i have excellent signal but video freezes often on dell d800 laptop
Does it freeze when you play a DvD on the system? if not, Video Memory is probably not the problem. I would say your problem is probably the streaming or downloading from the site you are watching the video from. Your line speed might not be high enough (for example, AT&T sells different line speeds and the lower the speed, the slower the download). How much main memory do you have? That might be a factor too. I would say you should at least have 1 to 2GB of memory.
Apr 20, 2012 | Dell Latitude D800 Notebook
I installed a memore upgrade in my Dell D800
You need to replace memory with one who is compatible with that model.
Feb 24, 2010 | Dell Latitude D800 Notebook
Dell precision m60 press the power button the screen blinks for a second the lights next to the power button stay lite for about 3-4 seconds then the entire laptop turns off. ANy ideas guys?
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil pmgibs1@verizon.net
Feb 23, 2010 | Dell Precision M60 Notebook
Dell latitude d500 wont charge.
If the original batteryand the system works on AC power, then replace the battery.
If the battery has been replaced, then it could be a motherboard charger failure
Jan 25, 2010 | Dell Latitude D500 Notebook
Dell Latitude D800 no view on screen anymore.
Try pressing function the whatever f key a screen icon is on
Jan 17, 2010 | Dell Latitude D800 Notebook
Dell D800 with LED codes during POST
Off Flash On is a Memory error.
  1. Remove battery and disconnect AC adapter.
  2. Remove both memory modules, then Install ONE module makeing sure it is fully seated, then connect AC and see if error goes away. Then try to other module in the other slot.
  3. Continue untill either issue is resolved by reseating or a bad module is identified.
  4. If no combination of RAM or replacement RAM doesn't resolve, then replace the motherboard.
Apr 11, 2009 | Dell Latitude D800 Notebook
Computer freeze/shuts down
check the virtual memory of your computer, make it atleasts 2 times the RAM
Apr 10, 2009 | Dell Latitude D600 Notebook
Dell D800 probles with windows media player
sounds like a memory allocation issue..check that first
May 04, 2008 | Dell Latitude D800 Notebook
Freeze problem, please help me
Turn of all power then unplug battery, disc drive, and make sure there is NO POWER on at all. Now take the laptop and turn it over and remove both or if you only have one memory Modules, If you only have one try it in the other memory slot and try to reboot laptop. I you have two module remove both and only replace one and see if it boot up normal after that, I think that may fix your problems, I have seen sometimes the memory module gets loose and will cause a freeze up. Hope that solves your problem
Dec 10, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
327 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
