Question about Kenmore Elite Oasis 27052 Top Load Washer
My son has a Kenmore top load electric dryer. It
My son has a Kenmore top load electric dryer. It dried about 20 minutes into the cycle and then shut down. All the circuits are ok, but it will not turn back on. What may be the problem. I do not have the model number.
    President:
  • 1,136 Answers
Hi, Check the door switch and the fuse. The fuse is the most common cause. You can also let the dryer cool down for an hour and see if it will restart. If it restarts, the motor might be going bad. It is hard to say without model# I'm afraid. I have not heard of a top load dryer but, these are common things to check.
Please let me know if I can assist you further.
Vic
Posted on Jun 27, 2009
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
My electric dryer shuts off after about 20 minutes of drying
ok sounds like you are using dryer sheets,,,dryer sheets coat the automatic dry sensors and fool the unit into thinking the clothing is dry,,,,replace the sensor or try to clean it if possable with a green scrubbie,,,,also try the time cycle it dose not use the sensor.......www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 Dryer
rmcfarland I am going to make an assumption. You are using the Automatic cycle. If so then this is wet load detection. Open the dryer door and at the bottom on the front you will see 2 metal bars. This is you moisture sensor. Clean that sensor with a mult purpose cleaner. If detergent and fabric softner sheets build up a coating on this sensor, the control will think you put in a dry load and shut down the dryer. Hope this helps.
Jan 25, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 27052 Top Load Washer Logo
78 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
