Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 Start-Up Problem.. beeps
Over the past few days I've gotten the blue screen with errors although I didn't write the error code... now when I try to start the pc, I hear a few beeps, and the numbers 3 and 4 are on.. 1 shows up but then disappears...
Any help would be greatly appreciated!
Thanks
  • robitaille_p Jun 28, 2009
    I removed, cleaned, and then reinstalled the memory sticks, and my pc is now back to life... :)
    Thanks very much for your help!!!
  • duanwalker May 11, 2010
    what is the error code given?
    President:
  • Dell Master
  • 1,314 Answers
Beeping on startup is a memory error. The blue screen you got was most likely caused by a memory error as well. First, take out then re-install your memory. If the error persists and you have more than one stick, test each one singly to find out which stick is bad.
Posted on Jun 27, 2009
  • Kevin Shafer
    Kevin Shafer Jun 28, 2009
    You're welcome, can you come back and rate this as solving your problem; I'd appreciate it.
  • Kevin Shafer
    Kevin Shafer Jun 30, 2009
    I'm glad your problem is solved. Can you please come back and give this a four thumbs up? Thanks!
Dell inspiron 570. 1 beep on start up. black screen. 1 light on the front
if you need support for your Dell inspiron 570, Blue Screen of *****, Fix Blue Screen Errors, Blue Screen Error in Computer, Blue Screen Error in Laptop, Dell Technical support Number, Dell computer support, Dell laptop support Number 1-800-204-4427 (toll-free) and more... http://www.delltechnicalsupportphonenumbers.com/blue-screen-of-*****
Jun 24, 2017 | Dell Computers & Internet
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Oct 11, 2012 | Dell Inspiron M5030 Laptop
Why is my lap top just intermittently beeping with a black screen
DELL BEEP CODES
Oct 07, 2012 | Dell Inspiron M5030 Laptop
I have a dell 580 inspiron thats does not turn on..before it turned on but now it just beeps and doesnt follow through with start up.......i had a blue screeen before this ....thanxx
Blue screen could be the windows files getting corrupted due to a virus, file fragmentation or a failing hard drive, overheating cpu or failing memory.
The beeping usually indicates a hardware failure, first open the computer and see it the CPU heatsink is in place properly seated and fan is connected and spinning.
Second with the PC off, remove and reinsert the memory.
These are just a few things to check , most likely the hard drive has failed and needs replacing.
pressing certain keys during bootup can sometimes isolate the issue, but only if the monitor still shows a picture
I hope this helps
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 23, 2011 | Dell Inspiron 580 Desktop Computer (Intel...
When i turn on mt pc it beeps 9 times and noyhing
What you are hearing is a "post error code".
The codes vary depending on the manufacture.
For instance if you have a Dell 2400 trying searching the web for "Dell 2400 post beeps".
Although I believe 9 beeps is commonly a CMOS error.
If so, you can try clearing the CMOS.
You will have to know how to get to the Computer BIOS screen to set things if you do clear/reset the configuration.
Jul 20, 2010 | Dell Dimension 4550 PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 Boot Problems!
You can probably try two things here.
1) Go to the BIOS and reset the defaults.
2) Clear NVRAM from your Dell computer. Here is how you do it.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4C1BF720A3E78F92E040A68F5A2811BE&journalid=7788D9829DCAA7C8E040AE0AB6E12FA2&Query=bnZyYW0=&SystemID=DIMENSION+5150/E510&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
487 people viewed this question
Alun Cox
