Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Does this tv set have a reset button
We have sound but no picture. the screen stop working.
  • tatersgoddes Jun 29, 2009
    thanks for the effort, and suggestions but it looks like me and my husband have to get a new t.v. must be the tube.
  • nbruce12 May 11, 2010
    OK so I tried what you said now what? I have sound no picture
    Problem Solver:
  • 9 Answers
Are you using HDMI? because if you are using HDMI you may have im not sure what you call it but its 1080P 1080i 720p 720i etc. you might have a channel that is on 1080p but your tv might only support 720P or so on but if thats not the problem its some type of hardware issue sorry if this dosint help.
Posted on Jun 27, 2009
  • 4 Answers
Do not throw that one out yet. It will probably be cheaper to have that one fixed than to get a new 50+ inch high def tv. Especially if you know someone with some basic electronic skills like pulling a fuse.
Try this:
When the TV is on and switch from one AV source to another (like going from DVD player to TV) does the TV show you what the source is (AV1, AV2, AV3, etc.) in the upper left hand corner? Or does that not even show?
Do you get your source from Cable company or just an antenna plugged into the rear?
What is the AV source that you are trying to get a picture on? (Chan. 3, AV1, AV4, etc.)
Posted on Jul 08, 2009
Sony flat screen tv-model KDL 40S4100
sounds like its more to do with the memory, there is system memory this is the one with the log, this memory only covers basic stuff ie turn on parts and log, then there is working memory that controls your settings and the pre installed setting, it could be that the settings have gotten mixed up, and it might just need a full reset in menu you should find return to factory settings, it should revert back to new and be ok after this has been set. hue sounds like its setting its self and reset should stop[ this on reboot.
Nov 09, 2017 | Televison & Video
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
I have a 42" Wall Mounted Plasma Screen TV Set have had it Now for aprox 5 Years with No problems at all. However this morning when I turned it on the Picture and sound was OK, and then the Picture...
NOTE:
Figure 1: Example of the reset button labeling on the LC2600N
7. Turn on the TV.
Jul 15, 2008 | Televison & Video
How do i get my tv back to home mode when it is in retail mode
Hello
[1] Press the green color button on your remote control to enter the Settings assistant menu.
[2] Select your Location with the cursor up/down and press the green color button.
If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings.
Press the green color button again to proceed.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
[4] Press the green color button to each time confirm your selection and to jump to the following screen.
The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
[5] Press the green color button once to store all the settings and to return to the TV installation menu.
Note: When you skip or stop the Settings Assistant, then the Standard settings
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
Feb 22, 2011 | Philips 42PFL5332D 42 in. LCD Television
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
No Picture or Sound on Vizio 52" Plasma TV
Try to use the reset factory reset feature. Unplug the set. After unplugging press the power button for 30 seconds. Plug the set back in and turn it on.
Apr 21, 2009 | Vizio L32 32 in. LCD HDTV
No picture
Resetting the TV
NOTE:
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 31, 2009 | Yamaha DVD-S540 DVD Player
No Picture, No Sound While Watching
Resetting the TV
NOTE:
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
NO PICTURE
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Nov 15, 2008 | Televison & Video
Picture but no sound
it happens to me alot lately i think its the actual hdmi port of the ps3 just unplug the hdmi cable and plug in and it should work just fine.
Jun 18, 2008 | Sony Playstation 3 (PS3) Console
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
303 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
