Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Center drew guide for Kenmore Ref. mod. # 596.65234402
Cant turn off oven in my stove Kenmore mod 3627526190
This is a major safety issue and I would not recommend attempting this repair yourself. Please contact a reputable repair service center.
Jan 14, 2015 | Kenmore Kitchen Ranges
My kenmore side by side mod.# 5965519400 is not getting cold or freezing in the bottom freezer...
Was this ref laid on its side for a period of time? You always have to allow the ref to sit upright for a period of time before you try to run it. You may need to call a tech to see if the compressor lacked oil when you turned in on... it may have burned up.
Oct 05, 2011 | Refrigerators
Replaced a waterfilter in my ref with wrong filter model
The new filter you used will not damage anything in the refrigerator, the only difference will be in the fill rate, it may fill slower than you like.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How is the impeller attached to the motor on mod 110 606 12990 kenmore elec dryer?
it is threaded on - we made a removal tool from a 1 by 6 board with a half-moon cutout in the center to clear the "cone" on the blower wheel. position it between the vanes and give the board a sharp rap - sometimes you have to put a wrench on the motor shaft to hold it
Aug 17, 2009 | Kenmore Dryers
Kenmore Mod. 795.77316600 s/n 603MRSS00142
Bad evaporator fan. Center fan behind the freezer back wall.
Sep 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore mod. 59672822200 ice
you should at least have power to ice maker. be sure to check while depressing the light switch assy. some ice amkers are wired through door light switch.after that there should be awire guid. tech sheet under the kickplate to guide you along if needed
Mar 13, 2008 | Refrigerators
Not as cool
heat is normal, it appears that condensor is blocked with fluff, there are two versions of this product, one has a radiator ooking grill in the back anf the other has the same behinf the lower front plastic trim remove trim and clean with vacuum cleaner this will allow refrigerant gasses to cool more quickly. Regards Advisor
Aug 12, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
