Question about Kenmore 57029 Side by Side Refrigerator
Kenmore model # 106.54512300 compressor check?
  • Kenmore Master
  • 4,655 Answers
You want to test your compressor. Call me or email me at appliancepartsse@yahoo.com
864-812-1887
Posted on Jun 27, 2009
4 Suggested Answers
vanni7
  • 163 Answers
SOURCE: Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Posted on Jan 03, 2009
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
  • 1218 Answers
SOURCE: my kenmore sidexside quit cooling and freezing.
Good day,
He can't, although it's a good guess. However, The compressor can be tested and run with a special test cord most all techs have.
It allows the compressor to be run independent of the rest of the machine and is the definitive test. I would not go forward unless that test is performed. Compressors are too expensive.
Posted on May 12, 2010
My air conditioner will not start up. It makes a humming sound but does not kick in. I have a Kenmore window type air conditioner . It is model 253.70151. It was bought in 2012.
Sounds that compressor is locked,first check capacitor, if ok then you need a hard start kit for compressor,if still won't come on bad compressor
May 06, 2015 | Kenmore Heating & Cooling
Compressor will not turn on the kenmore side by side refrigerator
check the start device on the compressor.you'll see a cover with a clip holding it on,unplug the machine,remove the clip and cover,slide the start device off of the compressor,to check it all you have to do is shake the device,if you hear pieces rattling around in it it's bad and you can check it with a meter but if the compressor isn't running,lights are on and fans are working,it will be the start device or the compressor itself.open the fridge door,look up on the right hand wall up near the ceiling and you'll see the model number,call your parts store,give them the model number and they will sell you the correct start device.good luck with your machine.
Nov 02, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side by side model 52569100 that is not cooling. Fan is running but not the compressor. Compressor is not trying to come on. Was wondering if it could have gone into defrost and not come...
If the compressor is not turning on you might want to check the relay switch.The switch is located on the side of the compressor usually with two wires running to it. To check unplug the fridge remove the switch and shake it, if it rattles you need to replace it.
Mar 01, 2011 | Kenmore Refrigerators
Compressor stop running on Kenmore model 596 75523400 can it be reset?
Hi and welcome to FixYa. I am Kelly
Is the compressor HOT to the touch? If so unplug the unit for at least 30 minutes and plug it back in.
If the compresor is cold then it may be stuck in the auto defrosting mode. When this happens usually either the 60 Deg F Bi-metal thermosat or a thermistor has failed. Items 30 and 31 this link: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00010?blt=06&prst=&shdMod=
(Evaporator
If that checks out then we start replacing the PTC relay and thermal overload on the compressor IF there is power to the compressor. Otherwise we start looking at temp controllers and themal fuses.
Items 10 and 11 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00011?blt=06&prst=&shdMod=
You make have to access the links above via this page http://www.searspartsdirect.com
Then enter your model number as 596.75523400 under find it fast / model search.
The other possibility is the electronic control item 5 under "controls":
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00006?blt=06&prst=&shdMod=
The only way to find out is to read out the circuits with a meter.
Thanks for choosing FixYa
Kelly
Oct 08, 2010 | Kenmore Refrigerators
Kenmore Model #10671192100 Refrigerator Rumbles-very loudly now.
Some kenmore fridges have a 10 year warrantee on the compressor and sealed unit. CHeck with your local Sears store if your's is one of them.
Nov 17, 2009 | Dishwashers
Kenmore Freezer Model 253.26732104 Compressor
the defrost timer may need reseting. when the defrost is on, it cuts power to the compressor so they don't run at the same time. it's usually behind the bottom front grate on the right side. also check the main circuit board. there's a fuse on it.
Jul 31, 2009 | Kenmore Freezers
Refridgerator is not cooling but freezer is working fine.
check the back of the refrigerator, you will most likely notice two compressors. one should be bad and has stopped working. you can get it replaced and the refrigerant refilled.
otherwise, check to see if the two compressors are working (if affirmative) then, there will be a damaged or ruptured tube where the refrigerant must have leaked away.
have this checked out and repaired.
thirdly, the cut-out may be bad or their is an electrical connection fault to one of the compressors. have this checked and corrected please.
Jul 08, 2009 | Kenmore Refrigerators
Kenmore model No. 253 11312100
Hi, No this freezer is not a self defrosting model. If it is defrosting while the compressor is running, you have a major problem.
If the compressor is not running, check the outlet for 120V and then check the thermostat to see if it is in the on position. If the control is on but the compressor os not running, check it for continuity. It must show closed while in the on position.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Kenmore Freezers
Kenmore 596.755 23400 problem with freezer
You can try to replace the relay and overload but on this model usually the compressors go bad. Call sears to check the warranty. The compressor should have a five year warranty.
May 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 57029 Side by Side Refrigerator Logo
250 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
