Question about Husqvarna Sewing Machines
Just bought a darning foot to use in quilting but don't know how to use it
  • 1 more comment
  • lesley_harri Jun 27, 2009
    Thank you for you advice. I had a play with it and I think I have got it now. Been hand quilting for years but want to give machine quilting a go. I think this will work withoiut me haviung to buy a new machine.
    Many thanks
    Many thanks
    Many thanks
  • 208 Answers
You didn't specify your machine brand or model which may make a difference in setting it up.
Using the machine with it in a cabinet or flat extension plate is necessary to allow easy movement and keep the fabric flat. Make sure that you have enough layers of fabric to give stability to the stitch.
With the needle bar in its highest position and the presser bar up, install the foot on the machine. Lower the feed dogs (if your machine has the feature), set the pattern for straight stitch and LOWER the presser foot. Hold the upper thread with your left hand and make one rotation of the handwheel with your right hand. Pull the top thread and the bobbin thread will come up with it. As you stitch, move the fabric in an even, fluid motion. This will take a little practice, but it will get easier with time. Make up some "sandwiches" to practice with. A sandwich is two pieces of cotton fabric with batting in between, usually six to ten inches square.
Your upper tension may need to be adjusted a number or two up or down. Experiment!
Posted on Jun 27, 2009
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
What darning foot will fit on a singer confidence 7463 for free motion quilting?
Yours is a low shank machine, and that is the most common type for newer machines of any manufacturer. eBay and Amazon both offer low-shank darning feet; I recommend the metal one with a metal large circular foot. That's my favorite, and I bought mine for $6.50 including shipping from eBay.
Jun 12, 2014 | Singer 3343 Mechanical Sewing Machine
Open-toe darning foot skips all stitches....help!
Hmm, have you installed a brand new needle? Make sure the needle is compatible with the thread and fabric. Sometimes a top stitch or microtex needle will work better for free motion quilting or darning.
https://www.superiorthreads.com/education/what-causes-skipped-stitches
https://moonlightingquilts.wordpress.com/2012/04/19/skipping-the-skipped-stitches-in-your-free-motion-quilting/
https://www.generations-quilt-patterns.com/skipped-stitches-driving-you-nuts1.html
Feb 26, 2018 | Kenmore Sewing Machines
Free motion quilting with the Singer 3343
I don't use a foot - I just gently guide the fabric and create designs.Hope this helps.Jimmy
Mar 28, 2012 | Singer 3343 Mechanical Sewing Machine
There is a loud squeaky noise when machine quilting a meandering stitch with a darning foot. The feed dogs are down, stitch width is 0, length stitch is 2.5. The machine does not squeak when using regular...
Is the darning foot aftermarket or genuine darning foot for your particular model...If it is aftermarket, it may not be the correct length. What is you model?
Jul 23, 2011 | Kenmore Sewing Machines
How to use a darning foot
Remove yourcurrent presser foot from your sewing machine, and attach the darning foot asyou would any foot. Darning feet look different, depending on the manufacturer,but most will maintain a "C" or "O" shape using eithermetal or clear plastic at their bases.
Drop the feed dogs, or use a cover plate on your machine if feeddogs are not available. If this is not possible, adjust the stitch length ofyour machine to zero or as low as your machine will allow.
Slide your fabric or quilt sandwich into place below the darningfoot. Lower the lever of the darning foot, and hold onto the upper thread withone hand.
Take one complete stitch, and pull up the upper thread to bringthe bobbin thread to the surface. Take multiple stitches in the same place tosecure the threads.
Run the machine as you free-motion sew or quilt your fabric piece,using your fingers to move the fabric instead of the feed dogs, until yourstitching is complete. Replace the darning foot with your preferred presserfoot when finished.
Read more: How to Use aDarning Foot ' eHow.com http://www.ehow.com/how_5143471_use-darning-foot.html#ixzz1AprkDyhm
Thanks for rating
Good luck
Jan 12, 2011 | Sewing Machines
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
Quilting
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Oct 03, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
152 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
