Question about Grohe Classic Kitchen/Bar Faucet 31.057.000...
The brown handle on the faucet no longer functions and the faucet is on with water running - can turn it off at shut off valves, but not sure if I can quick fix this issue? Not sure of the model - it can with the house. It's a gooseneck with a pull out neck for sprayer. It is in one hole on the corner of the sink. The handle pushes toward or away for on/off and you turn the brown handle up or down for hot & cold.
  • 297 Answers
If I were you i would just replace the faucet with something you know about.sometimes it's that simple.
Posted on Jul 22, 2009
Bidet keeps running
If you've tried turning off both shutoffs underneath and water still runs, then the shutoffs are also likely worn out and need to be replaced. If there is no way to shut off from that point, then the only other option is to have somebody turn off all water in the house near your water meter or main water line. In many places, hardware stores will sell something called a "water shutoff key", but depending on your location, it may have a different local name.
Once water is off to the whole house, turn the hot water on somewhere in the house to reduce pressure from your water heater before replacing your faucet and shutoff valves.
It is a good idea to take one of your old water shutoffs with you to a hardware store to make sure the new one would fit propperly.
If you know somebody who can take apart the faucets to check and replace just the washers, then it could be fixed with even less expense, if you would not rather replace the faucet with a new one that will last longer.
Oct 14, 2013 | American Standard Home
Hot water side slower pressure than cold side on one handle kitchen faucet
If problem is isolated to one faucet, then clog is located near that faucet.
I have same problem on one faucet when sediment and dirt collects at shut-off valve for some reason.
Problem can be at shut off or at supply tube or at faucet ... or all 3.
Repairs get things kind of wet so get out bucket and towels.
Take apart center mixing valve on faucet and turn water on to see if problem flushes out.
Disconnect hot side supply tube at faucet. Turn water on and see if that flushes problem out.
Remove shut off valve and turn water on to see if that flushes problem.
Replace shut-off valve.
Next place to look is elbow inside wall.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 19, 2011 | Delta 2402 Classic Single Handle Kitchen...
Jsut installed a tuscany Asti Tub and Shower Faucet, when the mixer handle is centered and you are running thru tub spout, water still comes out of shower pipe. it does not do this if solely set to hot or...
Check the valve body to make sure it is right side up. there will be a marking on the valve that tells witch is to go to the tub spout and witch to the shower head. If you have it right then you will need to disassemble the valve body and look for debris in the cartridge.
Feb 11, 2011 | Ldr Industries Home
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
How do you turn off the moen 82691 shower valve when new.
The stem in faucet may be in faucet upside down . you can try taking handle off remove nut that holds stem take it out make sure
you turn water off before doing this.
May 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Trying to replace rubber washer and springs in Delta single ball lavatory faucet. I seated the plastic top into the metal notch but, after tightening and opening the valve, the water does not run--after...
When diagnosing faucets, I always start at the discharge end. Remove the aerator and try to run the water. If you get water flow, then the aerator is clogged with some junk. If not, take apart the faucet ball again and make sure the rubber seats are seated correctly. Reassemble the handle and try to turn on the water. If that does not restore flow, remove the handle and carefully turn on the shut off valves below the sink to check for flow. Get the idea?
Apr 13, 2010 | Home
I am getting lots of brown flakes in valves
The brown flakes are most likely rust from either the tank or associated metal piping. They could also be from the anode used in hot water tanks to combat electrolysis. Does the water have a Sulphur" or "rotten egg" smell to it? Are you on a well? There shouldn't be so much, as to plug up the valves. Turn off your heat source to the hot water tank. At the bottom of the tank is a faucet. Hook a garden hose to it, run it out side where the hose lays lower than the faucet if possible and flush the tank untill you have clear water again. You may want to do this a couple of times to be sure you get rid of any sediment in the tank. When you are done flushing, make sure you have the air out of the tank by opening a hot water faucet until it runs clear with no "spurts" of air. Shut the faucet off and turn the gas back on, light the pilot light and see if the problem persists. Also have your water tested. Sears does this for free -just take a sample in and they will tell you what the hardness is.
Jan 15, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
Water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Jul 31, 2009 | Moen 2919 Chateau Two Handle Tub and...
Faucet running in off position
the fixture is set up so off is full to right as you go to the left the cycle is cold then hot if you don't understand turn tap all the way to right and turn on main if you need more help please post comment thank you for useing fixya please rate me
Feb 23, 2009 | Plumbing
Grohe Classic Kitchen/Bar Faucet  31.057.000... Logo
152 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
