Question about Garmin StreetPilot c340 GPS Receiver
Locating satellites freeze - Garmin StreetPilot c340 GPS Receiver
  • 37 Answers
StreetPilot c340 GPS Receiver ----
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
This is the Manual for your Model. Just do a hard reset.Should work fine. Let me know
Posted on Jun 27, 2009
Is there any product that stops freezing chanal
A channel freezing is usually an indication of a weak signal. If you're using an antenna, you might need to locate it higher or buy a better one. If you have cable or satellite, it's the station and you can't do anything about it, unless your RF connection is loose.
Feb 21, 2015 | Televison & Video
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
My toshiba Satellite M45-S265 freezes up
  • Hi, this freezing of the Computer all of a sudden can be the cause of a number of things; first have you "downloaded any new Software, Toolbars, or changed any Programs? Next check to see "How much Memory is available to you." Go to and open the Computer Properties, if there is (more Used Space than there is Free Space) than "I suggest you do a [Disk Clean-Up] from the same location. Next, when was the "Last time you preform a "Defragmentation of the files, this can slow down the Computer's performance aswell." Backing up your Data and Files is another way to free-up space; this can be perform by (Sheduling Tasks), go to the "Control Panel.' for this task. If any of these things do not apply, then the next thing I suggest is to "perform a System Restore," this will restore your computer hopefully, back to a Time or Date prior to the problem beginning. The [System Restore] can be performed from the Control Panel. "If this information to a solution was of help, rating it is appreciated, thanks
May 20, 2010 | Toshiba Satellite M45-S265 Notebook
Toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Feb 22, 2010 | Toshiba Satellite A60 Notebook
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba A105-S4074 freezing up
check the same from safemode and check for the results.
Last know Good Configuration can also be check.
If it is of no use, dear you need to reload the OS
Cheers - Parveen
Feb 08, 2008 | Toshiba Satellite A105-S4074 Notebook
Computer constantly freeze up!
apply heat sink paste in your processor
heat problem
Oct 27, 2007 | Toshiba Satellite A45-S151 Notebook
My toshiba laptop keeps freezing unexpectadly
Whats causing my Toshiba Satellite U205-S5002 laptop to keep freezing? Need assistance on how to troubleshoot the problem.
Oct 24, 2007 | Toshiba Satellite A135-S2276 Notebook
Garmin c330 freezing
I am happy to say my problem seems to have been solved. I found 3 possible solutions during my search - may need to try all of them to see if it works. 1) Reset by pressing the button under the faceplate. (Did not work for me). 2) Master reset - switch off the unit and press on the right bottom corner of the LCD and switch it on. Release the power button when it powers on, while pressing on the R lower corner. This is supposed to erase all prior data. I could not master reset my unit, for whatever reason. 3) Software update: http://www8.garmin.com/support/collectio... If you are a windows user you will want software version 2.4.1 as of April 3 2007. This worked for me. Thanks.
Sep 22, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
392 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
