How do I replace the clutch on my 1969 Morris Minor
Disconnect battery, remove screws holding floor down, the part covering the gearbox, remove starter motor, unbolt driveshaft at gearbox end, remove tin cover bottom of bellhousing, undo rear mount bolts, remove all bell housing bolts, with front seats removed you can lift the gearbox out of the car, ensure anexact alignment of the clutch plate and pilot bearing in the flywheel when fitting new parts, you can use a small socket and extension bar to align them. reverse procedure to refit components. good luck.
