Question about GE (PSS26MSRSS) Side by Side Refrigerator
Does not cool. Compressor is running, fans are
Does not cool. Compressor is running, fans are running, but freezer and refrigerator will not get cold.
  • slawlis Jun 27, 2009
    This was a used refrigerator. It had been unplugged for a week. After I cleaned it up, I plugged it in and it has never cooled down. It has been running for 2 days now. I unplugged it about 2 hours ago to clean the condenser coils. I removed the inside panel in the freezer. Only a small portion of the evaporator coils are frosted near the bottom.
    President:
  • 1,136 Answers
Hi, Look in the freezer section and see if there is frost building up on the rear inside panel. If the is frost, on of three parts are bad in the automatic defrost.
If there is no frost, the compressor might be weak and not pumping the coolant as strong as it should.
Remove the rear inside panel in the freezer sevtion and see if the evaporator is frosting at all.
Please let me know what you find so I can assist you further with this issue.
Vic
Posted on Jun 27, 2009
  • Victor
    Victor Jun 27, 2009
    OK, The compressor is bad. The little frost you see is a sign the compressor is not pumping like it should. Replacing the compressor is very costly. It would be better to get a new refrigerator.
    Vic
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Kenmore elite french door refrigerator and freezer not cooling
Check the compressor start device. The fans will be running and the compressor fan will be running but the compressor is problaly not running. If it is then it could be the compressor itself that is not oumping.
Mar 25, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag refrigerator / freezer compressor fan not running and some items in freezer appear to be thawing
Check to see if the fan mount bent somehow. The fan blade just might be jammed. If not see if the fan is getting power. The unit will not cool properly if the compressor and condenser are not being cooled down by that fan.
Dec 31, 2012 | Maytag Refrigerators
Refrigerator & frezzer no longer cooling. Compressor is still running , but condenser fan doesn't seem to be working correctly. Does the fan not working full time when the compressor is running...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Refrigerators
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Refrigerator is not cooling
hi thanks for the question you say the fridge is still running is the fan in the freezer running at the back is the compressor running if the compressor is not running and is very hot it could be a bad compressor is there a fan down by the compressor if there is a fan by the compressor is it going if not replace the fanthanks the appliance doc
Aug 14, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
696 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
