Question about Microsoft Xbox 360 Console
I tryed fixing xbox got 1 3 4 lights on i turned on xbox without dvd plugged in by accident what do I do
  • 37 Answers
Well do you have msn messenger? just email me or add me on msn its kickop1@ymail.com
Posted on Jun 27, 2009
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 14, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 was saying error e74 now it will just turn on but screen is blank.pls help me
Nov 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
"Key" issue - how to find
So you got the RROD on Christmas day, man that was a good present. The two lights (1 and 3?) usually means the system overheated and it cuts power to the CPU and GPU. If you did the bolts/washer fix, you actually do not want this to occur. You want it to stay on for 30-35 mins or so without doing the two lights (1 and 3). Usually you can do this by cooling the CPU fan and not the GPU. There is a good tutorial for the clamp fix here (http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm). It worked for my XBOX 360.
Unfortunately, It sounds like you turned on the XBOX 360 with the DVD drive disconnected. If so, I hate to add to your headaches but your XBOX 360 is probably banned from XBOX live.
If not, there is a good tutorial for replacing your XBOX 360 drive at: http://www.360-hq.com/xbox-tutorials-61.html It also talks about rekeying the drive.
If all else fails, you might trying talking to 360 Pros (http://www.360-pros.com/%28X%281%29S%28oyqpez55tpvpar451buhwgfi%29%29/xbox-360-repair-service.aspx). I know some people who have used their repair server and if you've opened the XBOX 360, you can not use Microsoft.
Jan 01, 2010 | Microsoft Xbox 360 Console
One red light on my concel
The Xbox 360 1 red light error is one of the most common problems on the Xbox 360 platform.Basically, the reason the Xbox 360 1 red light occurs is due to DVD or hard drive errors. Whilst these are not as common as graphics card malfunctions (which account for most instances of the "red ring of death" problem)
Therefore, if you have one red light in the power ring of your Xbox 360, you can be confident that this problem is caused by a hard drive error or a DVD problem. The next step in fixing the problem is to determine exactly which component the problem is with, ie whether the error is being caused by a hard drive fault, or whether it is being caused by a DVD drive fault.
To do this you need to consult the error code which appears on your TV screen when you try to turn your console on. If the code displayed is either E67, E69, or E79 then it is a hard drive problem. If it is E64, E65 or E66 then it is a DVD drive problem, which is slightly easier to fix. However, generally both of these errors are remedied by re-attaching the connector leads which can come loose, or by adjusting the "X" clamps on your console's motherboard.
Sep 01, 2009 | Microsoft Xbox 360 Console
1 red light on top right of console when lying flat
if you also get e-74 displayed on screen then the error is caused by an overheated gpu. unlight the 3 red light, this cannot be easily fixed since the gpu is soldered onto the motherboard. i'm afraid you are dead in the water, if you are outside the waranty you might as well buy a new xbox, there's no way to fix this one without replaceing the motherboard.
Aug 14, 2009 | Microsoft Xbox 360 Console
Xbox360 has 3 red lights
Its when the solder overheats and disconnects a wire in the xbox. If you have bought it within the last year, you can return or swap for new wherever you bought it. If not you will most likely have to send it off to xbox repairs.
Apr 01, 2009 | Microsoft Xbox 360 Console
Xbox dvd regions
http://members.cox.net/xboxfaq/faq.htm#Q5.4
Oct 05, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
44 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
