Question about Radio Shack Pro-95 Handheld Scanner
I have been trying to program Pro 95 for UHF Motorola Trunking
I have been trying to program Pro 95 for UHF trunking Motorola i have all the Freq and Id's but get no aduio when stops on an active channel. the control channels are programed and the base channel with off set but no luck getting any voice out of it only on the tunck channels
    Genius:
  • 1,239 Answers
Hi friend,
Did u checked ...is there any other channel broadcasting on same frequency,,also check whether any EW transmitting objects placed near it,,,
thank u,,,,,,,
Posted on Jun 27, 2009
Cannot recieve new Motorla trunking Feq after system upgrade on my Pro 95 scanner. What can I do?? Thanks, Ron
Hi.
They probably went into a digital trunking system. Your Pro-95 will only handle Edacs, Type I and II standard trunking.
Or they changed the trunking voice frequencies and the data (control channel) frequency.
Which system are you trying to listen to? Which city area ??
Feb 09, 2011 | Radio Shack Pro-95 Handheld Scanner
Need instuctions on how to program hand held scanner
Detailed programming instructions are in the factory manual which you can download and print, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
You may also want to visit www.RadioReference.com for a comprehensive database of frequencies and trunking systems in use in your area, and a lot of other useful scanning information - including programming software that will let you load trunking systems without spending hours punching keys.
Bill B.
Listening in since the 60's
Dec 15, 2010 | Radio Shack Pro-95 Handheld Scanner
How do I program it for triple truncking?
There is no such thing as "dual trunking" or "triple trunking." Such terms are used by manufacturers to indicate the number of trunking systems that a scanner is capable of monitoring. The PRO-95 is designated as a Dual Trunk-Tracking scanner because it is capable of monitoring both Motorola and EDACS systems. Programming a trunking system in to a scanner is a detailed process that requires a bit of research.
For details on active trunking systems in your area, and a lot of other useful scanning information, visit:
Once you have the system information you can follow the programming steps outlined in your scanner's operating instructions. If you don't already have the manual, you can download and print it here:
Bill B
Jul 24, 2010 | Radio Shack Pro-95 Handheld Scanner
TUNING
no there are no adjustments, you need to check to make sure tha tthe pro-95 you have is compatible with the trunking system in your area, i have the same problem with my pro-97 problem is just the codec that they use is too new for one of my scanners and the only way to listen in is to have the radio scan all output channels that arent control channels or transmitting all time
Mar 08, 2010 | Radio Shack Pro-95 Handheld Scanner
I have had my pro-95 for 8 years with no problems...now the trunking will not work...please advise
Your scanner may have had a logic "hiccup" for any one of many reasons, and a simple RESET may restore the trunking function.
RESET (will not wipe out frequencies or other programmed data):
- Turn the scanner OFF, and then then ON again.
- Insert a pointed object (paper clip, pen point, etc.) into the RESET opening on the side of the scanner, then gently press and release the RESET button inside the opening.
If the RESET doesn't solve the problem, you may need to INITIALIZ the scanner.
INITIALIZE (this action WILL delete all programmed data)
Welcome To Dual Trunking appears.
- Press 0 then 1 while Welcome to Dual Trunking is displayed. Initializing Please Wait appears for about 2 seconds.
Do not turn off the scanner until the initializing process is complete. When complete M000 will appear on the top line of the display, and Bank 0 Ch 0 will appear on the bottom line.
Hopefully one of these steps will restore the trunking. If not, the scanner may need professional help.
Bill B
Feb 18, 2010 | Radio Shack Pro-95 Handheld Scanner
Programing trunk system
the only way I know to program trunking would be manually one freq at a time unless you can find the software and cable to the unit.
Jun 01, 2008 | Radio Shack Pro-97 Handheld Scanner
Motorola Trunking not working
If you are getting "cross over" on freqs, then you need to take it in and have it repaired by a pro. You have some bad parts inside and only with the proper electronic gear can you locate them. Plus it will need to be retuned.
Aug 03, 2007 | Radio Shack Pro-95 Handheld Scanner
My 95 is way off - Freqs,Mode not working...Grrr!
mORE AND MORE POLICE AGENCIES ARE SWITCHING TO "DIGITAL TRUNKING". I CAN ONLY PICK UP PARTS OF MY LOCAL SHERIFFS STATIONS. RADIO SHACK HAS THE NEW dIGITAL TRUNKING SYSTEMS THEY COST ABOUT $500. I AM UP GRADING NOW. FOR TRUNKING ... WHEN YOU GET A ACTIVE CHANNELL KEEP HITTING THE RED TRUNK BUTTON TILL YOU SEE THE MOTOREOLA 5 NUMBEWR ID.THJEN HIT ENTER. I WANT THE NEW PROGRAMER THAT IS FAST ENOUGH TO FOLLOW DIGITAL HYPER-TRUNKING. ALL POLISE ARE GOING TO IT EVENTUALLY.
Sep 18, 2006 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
75 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
