Question about Dishwashers
My fisher paykel dishwasher started beeping both drawers. I shut the power off to them and let it sit for awhile. When i turn it back on they do the same thing.
  • 784 Answers
There is a leak on the top bottom housing and also the lower bottom housing. Until it dries out in these areas, it will continue beeping if power is plugged in. Please dry out and wait at least 6 hrs to dry out the sensors.
After this, you have to find out if your lid seal is still good. Take out the lid seal to inspect the distorted area. Before replace the seal, make sure the lid actuators working. Otherwise the new lid seal will cause the leak again. The parts for actuator from the top and the bottom are different. They are sold in pairs, so please both sides ( left and right).
Posted on Jul 03, 2009
Unable to start dishwasher
If you are able to select the correct program and the panels swithes are responding but the program does not start then it is likely the sensors inside the dishdrawer are faulty. Try to turn the mains power off and back on and see if any difference. Otherwise most likely the sensor that checks the drawer is shut or not may be faulty and telling controller that drawer is not shut. Provide your actual model number if you want me to look into the type of part and location otherwise call Fisher and Paykel service technician.
Jan 29, 2014 | Fisher and Paykel Dishwashers
DW (top drawer) will not start.Green light comes on when pushed to start but after 1-2 minutes, DW starts beeping and start button light turns red.
Turn the mains power off and back on after a little delay. If no change, some sensor in the drawer is faulty - most likely the drawer close sensor as it is telling the controller the drawer is not closed.
Mar 23, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykel DD24DCTB6 top drawer beeps instead of starting
It is very likely the two problems are not linked. Use small quantities of power detergent (Finish works best) to avoid foaming. The foaming usually triggers flood switch and shuts dishwasher. If the beeping is constant then most likely the flood switch is triggered. But if you get one or 2 beeps when you press start, then it is likely some sensor in drawer is faulty. Usually the drawer close switch is not working.
Mar 18, 2013 | Fisher and Paykel Dishwashers
Fischer and paykel drawer dishwasher has no power to drawer, power at outlet, was flashing F1 prior to shutting down, thanks
If you have a double drawer unit then please confirm what is happening with the other drawer. Most likely the base of the dishwasher under the bottom drawer has flooded and brought down the power with it. The power board sits under the bottom drawer. BE CAREFUL NOT TO TOUCH THE DISHWASHER BEFORE SWITCHING OFF THE MAINS POWER SUPPLY TO THE DISHWASHER AS THE CIRCUIT MAY BE LIVE AND GIVE A SHOCK. You will have to take the bottom drawer out and see what is happening under it.
Jan 16, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Can the beeping alarm be turned off?
usually if you turn the power off and on after a short delay the beep should go away. But the alarm fault code will keep showing on the display / drawer panel light until fault is fixed.
Hope this helps.
Feb 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
No power
top drawer turns on runs aprox 3 min then starts to beep and we have to turn it offthe clock pops up and and stays at 2;00
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Payke dishwasher top drawer
Try shutting off the power to the dishwasher for a minimum of 5 - 10 seconds then see if that resets the control system.... here is a link for the manual.. they have several trouble shooting sections within it to assist you.. http://www.fisherpaykel.com/global/customer-care/product-manuals.cfm
Hope this helps...
Sep 22, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
