Question about Insignia Digital-to-Analog Converter for Analog TVs
Vcr hooked up, no audio
Hooked up an older, plain vcr only, to my mom's older tv. The tapes play, and record, but no sound. When we watch tv through the vcr, there's no sound either. It is hooked up with 2 coax cables, with cable right out of the wall, no cable box, no cov box, just vcr and tv. There is sound with just the tv on. What did we do wrong?
  • sabglb Jun 27, 2009
    ok, thanks! I will have to buy the colored cables I guess. The vcr that was in place before this one was hooked up like I have the new one hooked up. There were no colored cables, only the older screw type co ax cables from the cable company. One in one out. We reversed them and got no picture.
    Problem Solver:
  • 4 Answers
This info is not correct...you need a triple rca cablr....red is right, white is left and yellow is audio......if you conect it all up and still get no sound...try another rca triple colored cable...
Posted on Jun 27, 2009
    Sergeant:
  • 160 Answers
From the VCR to the tv if you have RCA cables its kind of hit and miss where the audio cord goes. Only one of the jacks are for sound but it has to be plugged in to the right input. Audio is usually the white one. Just keep touching it to inputs until you hear sound start to come out of the speakers. Hope it helps.
Recording instructions
well if the vcr is hooked up and you can watch a show on it put in a tape that has a movie on it then press play if you can see the show take out that tape put in your blank tape find the show on your tv u wish to record press record try this before the show comes on record a little bit of a show like 30 sec or so then rewind and play back to see if it did record if it did just repete this when the show that you want to record comes on hope this is helpfull....
May 30, 2010 | Panasonic AG-DV2000 Mini DV VCR
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
How can I record TV show? What buttons do I push?
Well my friend, you have many variables that can cause this issue. Here is a list.
  1. Check the tape record prevention tab to see if it is not missing that will cause it NOT to let you record. Put a piece of scotch tape over it if you wish to use that tape.
  2. Make sure it plays back. If it does not play back, it might not record.
  3. Turn the TV on, look for Audio and "Video Out" and connect it to the INPUT Video Out and Audio Out. You cannot use the TV to power the VCR. The power plug must be connected to the wall outlet.
One of these should solve your issue.
E
Mar 02, 2009 | GE Televison & Video
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Stand Alone VCRs do not play pictures on my Insignia 24" TV
Did you try using teh SV cables supplied or the RF cable?
Easier to use the AV Cables. 100% should work. Connect Video OUT of VCR ro VIDEO IN of TV and AUDIO OUT (L) and (R) of VCR to AUDIO IN (L) & (R) of TV. Select AV or VIDEO on TV using TVs remote. Play a Cassette. should work!!
Apr 04, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
218 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
