Question about Sony KP-51HW40 51" Rear Projection Television
When the tv is turned on it looks fine, but after a minute or so the screen fades to blue. whats going on?
4 Suggested Answers
  • 39 Answers
SOURCE: Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Posted on Dec 14, 2007
  • 346 Answers
SOURCE: TV going Blue
malfunction of the convergence ics
Posted on Dec 23, 2007
  • 2336 Answers
SOURCE: picture comes on then fades to blue
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Posted on Dec 19, 2008
Picture comes on then fades to blue
Dec 19, 2008 | Sony KP-57WS500 57" Rear Projection...
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue screen
convergence ic and resistors require replacement and that you need to check for cracked solder.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 28, 2007 | JVC AV-56WP74 56" Rear Projection...
Hello......
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
KEEP FADING TO BRIGHT BLUE SCREEN
I'm about 90% sure it is the blue picture tube developing an intermittent heater to cathode short. I'm surprised the set isn't shutting down shortly after this happens. A service call will tell you for sure as it could also be a bad solder connection causing a similar symptom. My own procedure to check it out would be to GENTLY tap the neck of the suspected picture tube with a screwdriver handle to see if I could get it to come and go (Or get out my CRT tester and measure it with the power off). Obviously by holding the screwdriver blade you don't want to accidently short anything out as there is about 33,000 volts a few inches away from where I would be tapping. Nuff Said.
Feb 11, 2007 | Sony KP-53HS20 TV
Sony KP-51HW40 51" Rear Projection Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
