Question about Kenmore Refrigerators
How to replace an evaperator fan motor on my kenmore 795 frig
  • aknuese Jun 27, 2009
    It's the evaporator fan in the freezer for a model 795-7525 = we're not sure how to get the panels off. Is it done from inside the freezer or from the back?
    President:
  • 1,136 Answers
Hi, I can assist you but, I will need a model# so I cam look this up.
Vic
Posted on Jun 27, 2009
  • Victor
    Victor Jun 27, 2009
    Hi, The panel comes off from the inside. There is usually 4-6 screws holding the panel.
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag performa bottom freezer works but upper
First you should make sure your Evaperator fan is working. Open the freezer door and press the door switch in and see if you here the fan running.
If you dont here the fan you might have a fan motor problem.
Jan 07, 2010 | Refrigerators
I have a Kenmore Modle # 10657206601. The frige side is not cold but the freezer is. Do you have a wiring diag ?
is there frost buildup on the lower back wall in the freezer? defrost control/defrost thermostat/defrost heater. is the compressor not coming on but fan next to it is? compressor start relay. is the fan in the freezer running? evaperator fan motor. those are the most common problems. Greg
Jun 11, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Oct 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fan works light works but no cooling in either the freezer or refrigerater
The fan in the back of frig will run. Try replacing the evaperator fan and if the evaporator fan does not work replace the thermostat.
Jan 09, 2008 | Kenmore 53092 / 53094 Side by Side...
FAN MOTOR NOT OPERATIG
1. remove everything from freezer. 2. unplug freezer. 3. remove screws from back of freezer wall. 4.remove evaporator fan. (you will see it at the top of the freezer wall) 5.install new one.
Mar 12, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
176 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
