Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Lock a folder
I want to lock a folder through registry setting. How can I do that. And please tell me If I copy an .exe in a folder and create a shortcut of that .exe on desktop then I lock my folder through registry. Will my .exe's shortcut will run or not. If NO So please tell me how can I do that.
Rajan
    Problem Solver:
  • 4 Answers
To my knowledge, this is not possible with the registry. You can change permissions so that only your account can access the folder, or you can make the folder hidden.
Posted on Nov 08, 2007
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Tip
Great trick Lock ur PC yourself
ock ur pc.. open notepad copy and paste thescript below and save it .VBS extention
This wil create a shortcut.. run(click) it
set WshShell = WScript.CreateObject("WScript.Shell")
set oShellLink = WshShell.CreateShortcut(wshShell.SpecialFolders("Desktop")& "\LockWorkstation.lnk")
oShellLink.TargetPath = "%windir%\system32\rundll32.exe"
oShellLink.Arguments = "user32.dll,LockWorkStation"
oShellLink.Save
first select a folder for example i'll use a folder name movies in D driveD:\movies\
in the same drive u create a text file and type
ren movies movies.{21EC2020-3AEA-1069-A2DD-08002B30309D}
and save it as loc.bat
again u type in a notepad as
ren movies.{21EC2020-3AEA-1069-A2DD-08002B30309D} movies
and save it as key.bat
now in D drive u can see two batch files loc and key.. when u double click locthe movie folder will change to control panel and whn u double click key thecontrol panel will change to normal folder..
there are two more different tricks in dis site to lock ur pc down in a uniqueways.. donno where i have typed it..
on Oct 10, 2010 | Computers & Internet
Tip
An error message informs you that you cannot move or rename the Documents and...
To specify a different folder for the Documents and Settings folder during installation, follow these steps: 1. Run Winnt.exe or Winnt32.exe by using the /unattend option, and then insert the following entry into the Unattend.txt file, where z:\foldername is the path and folder name you want: [GuiUNattended]
ProfilesDir = z:\foldername 2. Install Windows. The path that you included in the Unattend.txt file is used instead of the default Documents and Settings folder.NOTE: This method does not relocate any key Windows components. Use this method if you require only user-specific data to be moved.
After you install Windows XP, to specify a folder other than the Documents and Settings folder for a particular user's data, follow these steps: 1. Identify the user's profile path. You can identify the profile path either by user security ID (SID) or by user path settings. The user SID method is preferred. To identify the user's profile path by the user SID loadTOCNode(3, 'moreinformation'); a. Use the Getsid tool from the Windows Server Resource Kit to obtain the SID. At a command prompt, use the following syntax: getsid \\ComputerName UserName \\ComputerName UserNameFor example: getsid \\windowsxp joedoe \\windowsxp joedoeThe results look something like this: = The SID for account WINDOWSXP\joedoe is S-1-5-21-1708537768-1993962763-1957994488-1003 b. After you obtain the user SID, start Registry Editor (Regedit.exe or Regedt32.exe), and then select the user SID under the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList To identify the profile path by the user's path settings loadTOCNode(3, 'moreinformation'); a. Log on to the computer as the user, and then type set at a command prompt. Note the setting for UserProfile, and then quit the command prompt. b. Log on to the computer as an administrator. c. Use Registry Editor to add the UserProfile setting to the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList d. Click the registry key, and then click Find on the Edit menu. e. In the Find box, type the value of the UserProfile setting, and then click Find Next. 2. In the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList registry key, change the ProfileImagePath value to reflect the new path that you want to use, and then quit Registry Editor. 3. Log on to the computer as the user, type set at a command prompt, and then verify that the path has changed.
Moving the entire folder loadTOCNode(2, 'moreinformation'); NOTE: This method does relocate key Windows components. Use this method only if you require the Documents and Settings folder to be moved or renamed and you cannot use the Unattend.txt file to change the name during installation.
To specify a different folder for the entire Documents and Settings folder, including key system components, follow these steps: 1. Log on to the computer as an administrator, and then create a new folder. 2. In the current Documents and Settings folder, on the Tools menu, click Folder Options, and then click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click to clear the Hide extensions for known file types and Hide protected operating system files (Recommended) check boxes. 4. Click OK. 5. Click and drag all the folders in the Documents and Settings folder to copy them to the new folder, except for the folder for the currently logged-on administrator. 6. Log off and then log back on, using a different administrator account from the one that you just logged off from. 7. Open the Documents and Settings folder again, and then copy the profile of the administrator that you just logged off from to the new folder. This extra step is needed because you cannot copy the profile of the account that is currently logged on. 8. Log off the computer, and then again log on to the computer as an administrator. 9. Start Registry Editor, and then click Find on the Edit menu. 10. Type documents and settings, and then click Find Next. 11. For every registry key or value that contains the original path, replace the value data or rename the value or registry key to the new path.IMPORTANT: You must complete this change in the registry for every instance of the original path, or your computer may not start. It is imperative that you update all registry keys and values with the new path.
12. Restart the computer. You can now safely remove the original Documents and Settings folder.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
CAPS WORK BUT LIGHT DOES NOT COME ON
Step 1:
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up. You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2. Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock. Create a Num Lock Script Configure a script that runs to automatically change the Num Lock state. Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code "set WshShell = CreateObject("WScript.Shell") WshShell.SendKeys "{NUMLOCK}" Save the file as "numlock.vbs," including the quotes to change the notepad file to a script. Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default. For a single user, copy it to their startup folder instead of All Users. Enter the BIOS Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings. Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS. Common keys include "F1," "F2," "Del," "ESC" or "F10." Consult your computer's documentation for specifics. Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot. Enable in Linux Linux is an alternate operating system. While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux. Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
http://support.microsoft.com/kb/314879 How do I enable the NUM LOCK key for the logon screen http://support.microsoft.com/kb/154529
Feb 25, 2013 | HP Pavilion Computers & Internet
My grandfather has a Dell inspiron 1501 and the num lock key turns on automatically when the computer boots up. The problem with this is the button is too small for him to see to turn off amediately so...
Please follow these steps.
Click Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Please let me know whether this works or no.
Dec 22, 2010 | Dell Inspiron 1501 Notebook
MC 9060 not retaining programming
We have the same problem, and according to our supplier we had to use the Regsave for saving the settings, due to internal proceudres, we haven't use the devices for a year, but now we have to use them again....
We have found this solution in the net, perhaps will help you...., now we are trying to find out the RegSave utility, if you find it, PLEASE e-mail me at alrapmttas@maersk.com THKS
quote
Some brief notes about the use of RegSave on Symbol 90X0 terminals, specifically the 9060 with the 802.11b RF option.
You will need RegSave_2_53_04.zip
Unzip this and locate the file RegSaveCED.exe in the 9050 folder.
Connect your terminal as a guest in ActiveSync and explore it using Win Explorer. Locate the c:\applications folder and copy the RegSaveCED.exe file to this folder on the HHT.
Now you can uncouple the HHT and click start menu and Windows Explorer to look at HHT's local files. locate applications folder and locate the RegSaveCED.exe file... double tap
Now screen RegSave EMEA TS appears.
In Registry section press "Create Template File"
Accept \Application\RegSave.tpl option offered
Click Create template and wait forever !
............. time passes ..................
The app rattles through all the registry entries and builds a file with them all in. Just when you assume it'll last forever it stops...
Now back to the main screen ...
Click OK (top right) to exit the app
--- oOo ---
Now set your IP parameters and RF bits... in fact anything you need.
--- oOo ---
Now re-load the RegSave app.
Press the button in the Registry section entitled "Save Current Configuration"
I got some missing file error here which I rode over roughshod... basically it's looking for a registry exception file. You can create this but and it can be a list of ignored keys but for our purposes it doesn't matter so I just said "Yes"
It'll do some stuff regarding comparing and checking for differences, then it saves the changed bits.
Now you can exit RegSave and try rebooting... it should have saved the changes to the Registry and everything should be the same as before
unquote
Feb 27, 2009 | Symbol MC9060-G
Need a folder lock software
yes u can have one from these; download at : FileLock
Jan 27, 2009 | Sony Ericsson K550i Cellular Phone
Antivirus 2009
I see these every day, note: also fixes AV 2008 and many others.
This Malware is known as "Rogue anti-virus" software.
This program will remove it: http://www.majorgeeks.com/downloadget.php?id=5360&file=10&evp=2e0d43eb67e1e71c0b31e62c003599c0
the website that has it also has a really good antispyware program called malwarebytes
www.malwarebytes.org
once you run a full scan in this program run this program:
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
it's another free antispyware. these are both professional grade removal software for free. I remove this stuff about 3 times a day. It seems this outbreak is the largest I've ever seen.
If you want a good protection suite that will keep it out buy a copy of NOD32 (www.nod32-av.com) another you may not have heard of, it will block this and many others before it even gets on your computer.
Jul 17, 2008 | Balance CN6555 Notebook
Antivirus 2009
Jul 16, 2008 | Dell Dimension 2400 PC Desktop
This copy of Windows did not pass genuine validation
1)Safe Mode
Reboot your computer and as soon as Windows logs off, start repeatively tapping the F8 Key on your keyboard.  • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…  • C:\Windows\System32 (Rename wgatray.exe to wgatrayold.exe)  • C:\Windows\System32\dllcache (Rename wgatray.exe to wgatrayold.exe)  Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,  Select the view Tab and under the Hidden Files option, select Show hidden files and folders
2) Safe Mode Registry
Click on Start, Run and within the open dialog box type regedit and click OK.  • Within the Registry Editor navigate your self to  HKEY_Local_Machine\Software\Microsoft\WindowsNT\CurrentVersi on\Winlogon\Notify\WGALOGON  • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)  • After Exporting the folder, DELETE the WGALOGON folder  • After deleting close all applications and Restart your machine back to Normal Mode  After being prompt of a successful validation, Restart your Machine
Nov 29, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
