Question about Dishwashers
The end start and top solo indicators flash simutaneously after wash cylce on miele dishwasher how is this corrected
  • 784 Answers
Please check out if you have wet area in the bottom housing
Posted on Jul 03, 2009
Miele dishwasher G1040 stop starting then all three lights start flashing
Sounds like bad control board. Try calling the guys from the service, I don't think you'll be able to fix this by yourself. Source: PDF Keep
Dec 27, 2015 | Miele Dishwashers
ALL LIGHTS ON PANEL ARE FLASHING??
All the lights on my incognito started to flash. This was after the drain/intake light started to flash also. I called Miele and they helped me to reset the lights flashing. They said that when all lights are flashing that this indicates an overheat condition. They asked if my filters were clean and I thought they were. However, my wife had started to use liquid dish washing detergent and the liquid detergent had plugged up the filter screen at the bottom of the dishwasher. I cleaned it good with a scrub brushing and boiling water. This fixed the problem. Bottom line, don't use liquid dish washing detergent in a Miele, only powder.
Apr 08, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
All lights flashing
Try powering off the machine using the main power switch for at least 10 seconds, then power back after holding down the top solo and start/stop simultaneously.
You may need to check the drainage pipe and water inlet for blockages. Under the filter inside, you can remove part of the drainage system by removing the silver clip and pulling on the plastic segment.
Wash this through, it has a lovely ball bearing inside, but don spend too long wondering how big it is. Big it is.
Check the tubes, for kinks etc... Always disconnect the water supply before detaching the inlet, and be prepared for a mess, if you do decide to remove the drainage outlet pipe.
Failing this, the following post may help:
Check out this solution to the Miele 24 in G646SC Plus Free Standing...
Feb 18, 2014 | Miele 24 in. G646SC Plus Free-Standing...
The blue indicator light will no longer come on at the end of the cylce
Hello Loucinda Stanley - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Select a normal cycle let it run and then the indicator light should display at the end of the cycle. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Jan 16, 2013 | Electrolux 24 in. EDW5500DSS Stainless...
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
Miele G880 dishwasher, stuck in "Top Solo" mode.
If the unit is really stuck in 'top solo' then the most likely culprit is the top solo solenoid valve located off to the side of the circulation pump. It's most likely jammed in the engaged position. You will have to uninstall the dishwasher, lay it on its left side and remove the bottom panel to access it.
Feb 13, 2010 | Miele G880 Dishwasher
3 lights are flashing at end of dishwashing cycle cycle
I shut off the dishwasher, held a few of the buttons together at the same time, let it sit for 5 minutes, then restarted it and it worked!
Mar 21, 2009 | Miele Dishwashers
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
