Question about Compaq Computers & Internet
On a compaq presario v2000, latch switch that releases battery is stuck. Won't open and release battery. Afraid to push to hard and break it off.
    Problem Solver:
  • 11 Answers
Sounds like you will have to take it all apart & remove the Motherboard to get where the spring is & the lever to make sure it not busted or just jammed.
Posted on Jun 27, 2009
How to reset bios on compaq v2000 laptop
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
Need to remove battery, dont know how compaq presario v 3000
Hello sexychispa. To remove the battery of your Compaq Presario v3000, start by turning the laptop over so that the bottom side is viewable. Look for a rounded slot in the bottom that has a sliding tab within. This is the battery release latch. Using your finger, slide the latch and hold to release the battery. With your free hand, assist the battery out of its compartment and allow the release latch to slide back into place.
For more information on the process, be sure to view this link to HP's guide to removing batteries from Compaq laptops.
Hope this helped!
Feb 27, 2011 | HP Computers & Internet
How do I change the batteries? I'm afraid I'll break it.
There are a few ways most wireless mice open up.
#1: The back of the mouse slides off when pushing down and back from the center of the mouse.
#2: There is a latch or a button underneath the mouse that will release the top cover to reveal the batteries.
#3: There is a latch on a door underneath the mouse that will reveal the batteries.
Nov 28, 2010 | Logitech Cordless Mouse
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
How do i replace the presario v2000 battery? I cannot take the old battery out.
The cover may have been jammed if the laptop was dropped.
1. Use a stiff letter opener and run it along the edges of the battery cover.
2. Move the mechanical lock switch to open
3. Use the stiff letter opener to pry the battery out.
4. The goop you find is probably dried-up coffee, or some energy drink...
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
Battery cover on back is stuck on. no way to get open without breaking it
Press on it with both thumbs in the depressed area and push down and toward the end.  There is a small latch behind the depressed area.  By pushing down as well as toward the end of the unit you should be able to get the latch to release and the cover will slide toward the end.
May 29, 2009 | Logitech Harmony 670 Advanced Universal...
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
May 07, 2008 | HP Compaq Presario V2000 Notebook
Screen not coming on
It is a display problem.Better to take any nearest service center.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
Battery stuck in compaq presario latch wont release it
You'll need to disassemble the notebook, i.e remove keyboard and such.
Jan 13, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
402 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
